Y-pipe installation help
Old Apr 27, 2005 | 09:16 PM
MaxCanesFan's Avatar
I am planning on installing the warpspeed y-pipe and warpspeed cat with a new stock muffler and reuse the B pipe from the car.
What other parts will I need, and what things to be cautious of?
Never replaced a whole exhaust before and would love some tips on it.
Old Apr 28, 2005 | 12:20 AM
maximazation's Avatar
just make sure you use the gaskets, make sure there no clearence problems, and tighten the bolts tight to they dont get lose and rattle.
WD-40 is also a good thing to have handy as old and rusted bolt are a b!tch to take off w/o the magic spray (WD-40).
Old Apr 28, 2005 | 12:24 AM
eckohb's Avatar
na na na, dont use wd-40, use Pb blaster for those bolts. Every bolt that you will be replacing/removing, DRENCH it in pb blaster. Do it the night before you plan on install your y pipe, like 3-4 times if not more. youll thank yourself later.
Old Apr 28, 2005 | 03:30 AM
lilaclucymaxima's Avatar
Team Ramrod
The package included gaskets and a hanger. I had to go out and buy 8 nuts and 2 bolts (the 2 bolts for the catalytic converter) <--- those were HORRIBLE
Old Apr 28, 2005 | 07:49 PM
bump for anymore advice...starting in 10 hrs..
Old Apr 28, 2005 | 07:56 PM
MDeezy's Avatar
exactly. soak it good well in advance so it can start soaking into those bolts and hopefully wont take as much energy to break free when your ready.
Old Apr 28, 2005 | 08:04 PM
The Deal's Avatar
Do you have to go into the engine bay to change the y pipe??? prolly a dumb *** newbie question thats gonna pis half of you off but hey? It'd take me a week to search the stickys...
Old Apr 28, 2005 | 08:05 PM
MDeezy's Avatar
no just underneath, just jack it up a good height so you can get underneath, you'll need the room to try and break those 3 bolts free.
Old Apr 28, 2005 | 08:20 PM
mrgreek's Avatar
lol ive been here a month or two and those bolts have become legendary...ill worry about y-pipe when the time is needed
Old Apr 28, 2005 | 08:34 PM
Any advice not on the y-pipe but the installation from the new cat to the old b-pipe. Reading the past 10 pages of posts, it seems like at times either the gasket/O-ring doesnt fit snug.
Puppetmaster's Avatar
If all else fails, you could try to take it to a muffler place to torch the bolts off and replace em with new hardware to make things easier for your install. Its usually less than an a half hour's work for em and it'll save you a lot of time and energy.
Old Apr 29, 2005 | 03:34 AM
Team Ramrod
You do when you disconnect the O2 sensors.
Old Apr 29, 2005 | 05:10 AM
CreativeDesignz's Avatar
just take the o2 sensors out with an open ended wrench...keep them plugged in and hangin there. i did not need to replace the bolts that were from the headers down to the Y pipe cuz mine were still in pretty decent shape. the cat bolts were another story. I just ground them off and then drilled new holes for the flange. other than that it was a piece of cake...i had taken everything off the day before, thank god because im the most impatient person in the world. all in all it was an easy install. 15-20 minutes.
Old Apr 29, 2005 | 09:20 AM
MaximaSE96's Avatar
Maxima Owner
f PB Blaster use THRUST from Castle way better
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
