WTF??RPMS go up and down with the heater.....
Old Apr 28, 2005 | 11:25 AM
DuMKuH's Avatar
Hey everybody, I am trying to get some information about whats going on with my car, its 98 se 5speed 95K miles. Ok, so the car works and idles perfect but as soon as I turn the heat on the RPM go up to 800 and some times stay there, some times go back to normal(650), and when I turn th heat off the RPM go to about 300-400 and then back to 650...?!?!Thanks in advance
Old Apr 28, 2005 | 11:40 AM
dayglo's Avatar
yeah man dont worry about it, its normal
it should usualy stay up if youve got it turned on, untill you turn it off or put it on manual.
with mine, set to auto, it will raise to 8-900 or something, but if you hit up or down on the fan speed to turn it on, instead of hitting auto, it wont raise the RPMs. ..somehting like that ^^ someone correct me
you can try it out and see how it works for you
Old Apr 28, 2005 | 12:24 PM
DuMKuH's Avatar
just its not climate control-its just manual....but is it supposed to go till 300-400 down after you turn it off and then come back to normal idle rpms???
Old Apr 28, 2005 | 12:55 PM
Loe max's Avatar
Have your charging system checked to see if its within 14.1-14.7 volts
Old Apr 28, 2005 | 02:04 PM
WickedMax3's Avatar
Yeah i think its normal for all cars to idle higher when the heater or ac is turned on.
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
