Antenna Sticks
Old Apr 28, 2005 | 03:29 PM
97maximaman's Avatar
Antenna Sticks
I dont know if this is really bad or not but my antenna gets stuck about 3/4 of the way up when trying to extend it. The radio gets great reception but it just annoys me. Please dont tell my i have to replace some expensive part!
Old Apr 28, 2005 | 03:37 PM
MAXRB8's Avatar
If you consider $12 an expensive fix then don't click on the link below:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33639
Got mine from these guys, we'll packaged comes with DIY instructions, can't beat the price, dealer up here wanted $50 for the same thing!!!!!!!!!!
But try cleaning the mast first
Old Apr 28, 2005 | 04:08 PM
Thanx alot maxrb8. For $13 i can't resist, lol. I thought you were going to tell me to buy some $50 part.
Old Apr 29, 2005 | 06:50 AM
renatonetmail
maintenance is the key ...every now and then get some liquid wrench and spray it around the mast while still functional and wipe.
Old Apr 29, 2005 | 08:09 PM
texasmax's Avatar
If it's stuck because there's dirt stuck in there or it's just not lubed enough, try the liquid wrench/wd40/whatever while the antenna is moving up and down, and wipe it with a rag at the same time. If there's a bend, even a small one, you're probably going to need a new mast. I spent hours with needlenose pliers trying to straighten mine, and I never got it working to where it would go all the way up and down without a problem.
Old Apr 30, 2005 | 08:57 AM
To tell you the truth, Tex, i actually used oil on the mast but nothing happened. There are no bends but im sure there's rust. The problem started out when the antenna would only go down half way. Then one day it went down but now it will only go up half way, lol. I'll try some white lithium grease when the rain stops but i have a bad feelind i'll be taking a trip to autozone for a new mast.
Old May 1, 2005 | 12:34 PM
97BlackSEGold's Avatar
No its probably not the mast. Pull the lining out of your trunk and remove the entire power antenna assembly. Open it up and clean all the dirt and grime out of the gears in there. My antenna stopped going down this winter so i cleaned out mine, and it made all the difference. The gears in there get covered in so much dirt that the teeth don't catch all the way and it slips when its pulling the mast down.
Old May 1, 2005 | 01:22 PM
joooowan
my friend used WD40 on his car and it fixed it
Old May 1, 2005 | 01:46 PM
decided to replace the mast but thanx anywho
chisam14
Nov 6, 2018 08:56 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
