stalling when car isnt warmed up?? and in reverse only
Old Apr 30, 2005 | 08:57 PM
97MaximaSE's Avatar
I have a weird problem with my car....its runs perfect when warmed up. Only problem i have is when its not warmed up(like the first start in the morning or after getting out of movie) the car will stall or the rpms will stumble in reverse. any ideas of what could be causing this??
p.s. so far to try and solve this i replaced 2 worn vacuum hoses, a 6 plugs, cleaned out my tb and iacv. nothing has worked yet
Old Apr 30, 2005 | 10:09 PM
5alive's Avatar
Do unto others...
You cleaned the IACV, but is it operational?
Old May 1, 2005 | 05:23 AM
97MaximaSE's Avatar
well i not throwing a code for it and when im at idle the car seems to hold it fine....its more or less when i put it in reverse and hit the gas...if i just let the car roll its mint
Old May 1, 2005 | 05:47 AM
1996blackmax's Avatar
Check the resistance on your CTS (Coolant Temperature Sensor). The procedure is outlined in the Haynes manual. Even if it is not throwing a code it may still be acting up.
If this is the problem, it is an easy part to replace, and it only cost about $25 bucks.
Old May 1, 2005 | 05:59 AM
lilaclucymaxima's Avatar
Team Ramrod
Same thing happened to me. My ECTS is new, my spark plugs are new. Basically all the major parts under my hood are new. It doesn't do it as bad now that the weather is warmer, it was MUCH worse in the winter. Still don't know what could be the problem. Maybe the torque converter is going.
Old May 1, 2005 | 07:44 AM
97MaximaSE's Avatar
ive already replaced the cts about 30k miles ago.....one thing i did notice today was a loud hissing around my pcv valve and when i removed it i didnt hear any clicking so im gonna try and buy a new one. i have the whole FSM on pdfs so im gonna see what the coolant temp sensor should be and check it out anyway
Old May 2, 2005 | 02:17 PM
97MaximaSE's Avatar
ok update.....car still stalls...i found if i hold the brake and hit the gas in reverse it will eventually just die. works fine in D though. what do all those connectors on the iacv do? also it does it when its hot and cold
Old May 3, 2005 | 09:46 PM
97MaximaSE's Avatar
ok figured it out....one of the wires in my harness that broke before has broken again.....this time i melted the crimper tool around the wire and all seems well
Old May 4, 2005 | 07:05 AM
Go1maxn's Avatar
I seem to have the same problem with my 98SE. It stalls on when trying to put it in gear when the car is cold. How did you resolve this issue?
Old May 4, 2005 | 07:54 AM
Team Ramrod
What harness?
Old May 4, 2005 | 08:06 AM
C3nthusiast's Avatar
I figured out why my car was stalling reverse out too!!! I have an Injen CAI. The wires going into the MAF went bad from all the movement of the CAI piping. I soldered on a new one and she runs perfect.
Old Mar 6, 2009 | 09:14 PM
Jay588's Avatar
Sorry to bump an old thread, but i am having this exact problem. Is it safe to say this is a MAF issue? One day it was real bad, kept stalling when trying to park and i took a look under the hood with the engine running, the MAF wiring had a leaf stuck between(dont ask) and after removing it, it stalled again. started up again and then no problems. But just today it has started again, but only in reverse. Help me out.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
spidgeon
Aug 18, 2015 05:46 AM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
