Car wont start on first try!
Old May 2, 2005 | 01:17 PM
VQ30de96's Avatar
Everyone now and then when i go to turn my car on it doesnt start till about the 10th try? its on a rare occasion but is this foreshadowing somethig down the line or is it just a random little bluff? if anyone has any info or knows whats wrong it'd be much appreciated!!! thanx
Old May 2, 2005 | 01:20 PM
maxgtr2000's Avatar
KH3 by popular demand
2 words...tune up
Old May 2, 2005 | 01:21 PM
MaxCanesFan's Avatar
Ignition switch...starter....
kormax97
starter
10char
Old May 2, 2005 | 01:53 PM
MDeezy's Avatar
starter, if you see some black smoke comming out the tail pipe after starting then good chance tis starter.
When was the last time you did a tune up?
Old May 2, 2005 | 04:07 PM
Nismo3112's Avatar
Custom User Title
ignition switch or the starter. My problem was the ignition switch. When my buddie's starter died, it just died. No more cranking.
Old May 2, 2005 | 05:20 PM
Mishmosh's Avatar
It could be any number of things. How does it sound as it's cranking? Also, have you done the basic "tune up" type maintenance: fuel filter, spark plugs, fluids, etc?
Old May 2, 2005 | 06:03 PM
PTownMax's Avatar
I still miss the max
check for codes?
Old May 2, 2005 | 06:06 PM
dgeesaman's Avatar
Maintenance Monster
Do you get cranking at all? If so, try looking for codes - it might also be a crankshaft position sensor or camshaft position sensor. I had to pull the key and re-try when my CmPS was failing.
Old May 2, 2005 | 07:06 PM
speed racer's Avatar
Have you done a tune up lately? This might be a good place to start. It does sound like the starter. One advise if your car ever stops working take a big wrench and point the end on the starter than wack it a couple of times with a hammer. This will shake the $**t out of the starter to work. Good luck
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
