Need Help On Foglights?thanks
Old May 12, 2001 | 04:46 PM
greenmax's Avatar
I LOOKED TODAY UNDERNEITH MY CAR AND SAW THE FOGLIGHTS WIRES AND WANTED TO KNOW IF I BUY THE FOGLIGHTS WILL THEY TURN ON WHEN I TURN ON MY LIGHTS.BECAUSE I TESTED WITH A VOLT METER AND THERE WAS NO POWER.WHAT CAN YOU ADVICE ME TO DO?THANKS IN ADVANCE
Old May 12, 2001 | 09:34 PM
Gotrice4's Avatar
If you have a gxe, which more than likely you do, you will need to buy a fog light kit and that will include the proper fuses and a new headlight stalk, the new stalk will have the switch for the foglights
Old May 13, 2001 | 01:52 PM
Sonic's Avatar
Do you have a power drivers seat? If you do then you can install it, otherwise, you are out of luck. Use the search function and search for foglight install in the 4th gen forum. There has to be at least 30 threads about this. If you have a GLE, you are prewired. If you have a GXE with C&C package you are also prewired. Otherwise, you are out of luck.
Old May 13, 2001 | 06:48 PM
greenmax's Avatar
MY THING IS THAT I DONT WANT TO REMOVE THE STEERING WHEEL OUT I WANT IT TO TURN ON WHEN I TURN MY LIGHTS IS THAT POSSIBLE?OR DO I GOT TO INSTALL HEADLIGHT STALK? THANKS IN ADVANCE
Old May 14, 2001 | 10:54 AM
Sonic's Avatar
You don't remove the steering wheel when you install the 'switch', but you do have to take off the trim around the steering wheel, about 6 screws. The foglight switch is integrated into the turn signal stalk and thats what you replace around the steering wheel. BTW, please turn off CAPS LOCK.
Old May 16, 2001 | 02:35 PM
nelzavala's Avatar
I just got my fogs about a month ago. They came with the fogs, mounting brackets, cutting templates, and new turn signal stalk. They were $197 with shipping from courtesy.(including our Maxima.org discount)
Ps. I shipped the instructions to gtr_rider in this forum, ask him to scan the instructions and e-mail you.
oh, You do need the new stalk because you need the swicth that comes attached to the headlight switch to turn the fogs on.
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
