What Is Wrong?
Old May 4, 2005 | 06:50 AM
BLAZIN's Avatar
What Is Wrong?
There is Strong hesitation during startup. The starter will turn for about 10 seconds, then i will wait for a minute and then I will turn it again. usually on the second try it starts up. This is very annoying and cannot be good for the starter or engine. Rpms sometimes jump around as well just after startup for about 10 seconds then everything runs normal for the rest of the day. Its just that initial startup of the day when it is cold.
Should i start as small as replacing sparkplugs and see if that helps? Could it be the coil packs or ignition? Please help.
Old May 4, 2005 | 07:26 AM
adithius's Avatar
What kind of maintenence have you done so far?
Have you changed the fuel filter lately. I would also clean or replace your crankshaft.
Old May 4, 2005 | 07:31 AM
BLAZIN's Avatar
The fuel filter is good. I have gotten fuel injectors flushed. I havn't done much and I dont have a whole lot of money to guess around. What about the crankshaft?
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
