2 Exhaust Questions and 1 Starting Question
Old May 4, 2005 | 09:33 AM
KRMaxima21's Avatar
I bought my 95' about a month ago and I noticed that it won't start unless I keep pressing my foot on the gas pedal and then it'll start. If I crank it the first time without giving it gas it wont start. The second time I crank it, it'll start up fine. Anybody know the reason behind this?
Also, under normal acceleration the car runs fine but then I pretty much lay my foot down hard on the gas it'll start to hesistate a little. I noticed underneath there is some sort of thermal wrap under the car which looks like it's wrapping the flex section. Could it be the o2 sensor in the catalytic converter not getting enought exhaust because there's a leak which is making it run rich?
Finally I went to order a Warpspeed y-pipe and they said they're not selling the Superflo for now because of leak issues. Anybody on here have the Superflo (the one with no flex section)?
Old May 4, 2005 | 09:37 AM
thumper10s's Avatar
i did but mine leaked so i got the regular one
Old May 4, 2005 | 10:05 AM
MDeezy's Avatar
Starting: Could be your starter or ignition switch, I had a bad starter that would drag and sometime pressing gas would help it start.
When was the last time a tune up has been done?
hesitation could be clogged cat, coil packs.
Do you have a CEL?
Old May 4, 2005 | 10:22 AM
Jatan's Avatar
Starts with the small things first: tuneup (plugs, air filter, fuel filter, PCV valve) and clean your throttle body and check for the hidden knock sensor code
Old May 4, 2005 | 10:41 AM
NCSU_MAX's Avatar
Maximoneypit
Ive got one and its leaking as well. theyre sending me a new one soon.
rbuswell
Nov 17, 2016 04:54 AM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
