How often should I change my spark plug wires?
Old May 13, 2001 | 06:06 AM
Hercules's Avatar
I bought my 96 Maxima a few months back with 80K miles on it. I made a tune up which replaced the filters and the spark plugs (NGK). I haven't changed the spark plug wires though. Is there a way that I can check if the wires are still good? Or should I change it according to the mileage?
What brand should I go for if I need to replace it? How much do they cost? Any input is appreciated. Thanks.
Old May 13, 2001 | 06:17 AM
ny96max's Avatar
We dont have spark plug wires. The motor uses ignition-coils that clip to a wiring harness from the ignition system. You will know if the wiring is bad cause the motor will be missfiring,have lots of hesitation and idle like *hit. All you have to change out is the plugs to NGK from Nissan.
If you have this problem its probably due to a burnt-out coil. I had this problem when doin my 60k tune-up. Took me about a week and $200 in new sensors to figure out it was the coil, $70.
Ant
Old May 13, 2001 | 02:19 PM
max808's Avatar
If you need to check if they are still good, chances are they are still good. You'll know by misfirng.
Old May 13, 2001 | 02:28 PM
Sonic's Avatar
Like ny96maxse said, we DO NOT have spark plug wires.
Old May 13, 2001 | 02:39 PM
Hercules's Avatar
Silly me, haha. I was misleaded by those guys at the repair shop. Thanks to you guys for clarifying!
Old May 13, 2001 | 02:42 PM
Sonic's Avatar
And while we are at it, we also don't have a timing belt, we have a chain.
Old May 13, 2001 | 06:27 PM
redmaxpa007's Avatar
i SeE what you did therE
i think the guys at the shop were trying to get some more monrey out of you...
Old May 13, 2001 | 09:25 PM
D-DOT's Avatar
I think he should take it back, let them do the work and when their finish tell them you want to keep your old wires too then sew the hell out of them
Old May 14, 2001 | 08:01 AM
ajaffee
Sew?
Sew the hell out of them? Why? Is it better if they are all attached to each other with thread?
Old May 14, 2001 | 08:25 AM
Re: Sew?
i was thinking the same thing.... j/k
Old May 14, 2001 | 09:07 AM
NisMax95's Avatar
Re: Sew?
Yeah, of course it is.. Then they can't run when you call their bluff! Sew 'em up and make 'em pay!!!
Old May 14, 2001 | 10:21 AM
Sonic's Avatar
Sew them up and then whip them with the timing belt!!
Old May 14, 2001 | 11:41 AM
medicsonic......i would love to see that!!
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
