How to remove Maxima Emblem?
Old May 8, 2005 | 01:28 PM
VQ30de96's Avatar
Tomorrow i'm going to put night shade on my tails and would like to debadge the maxima emblem from the rear along with the nissan badge. is there any particular procedure i should follow or anything i should know before taking them off? or even how to take them off? ALso if anyone else did the nightshade, when they took off the tails hows did they get around the white caps on the bolt on the inside of the trunk? any help is much appreciated!!!! thanx!
Old May 8, 2005 | 01:36 PM
2 Da Max's Avatar
i used a sawzill, but any saw is fine, like a hak saw or something
Old May 8, 2005 | 01:37 PM
Crockpot's Avatar
i used a dremel
Old May 8, 2005 | 01:38 PM
PandaXpress's Avatar
these guys are just clowning you..lol..anyway...just use a fishing line to debadge the trunk and get some goo-off or something..so take off any residue that is still there...then buff it out with some wax or a clay bar..and your set.
Old May 8, 2005 | 01:39 PM
i believe its in the HOW TO'S section of the forum
Old May 8, 2005 | 01:40 PM
2 Da Max's Avatar
www.craftsman.com
Old May 8, 2005 | 01:43 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
dont do it, your car will look ugly without the emblems.
Old May 8, 2005 | 01:45 PM
Crockpot's Avatar
http://www.dremel.com/html/home_fr.html
Old May 8, 2005 | 01:51 PM
Spaniard's Avatar
I managed to use dental floss w/o much trouble..!
You are going to want some glue remover. I used 3M General Purpose Adhesive Cleaner.
Old May 8, 2005 | 01:55 PM
killcrap's Avatar
its called 3m adhesive and wax remover. available at walmart auto paint area. or if you go to home depot, get a can of goof off. and soak the adhesive for a couple of minutes and then use a cloth to just wipe it off. then claybar and wax that as s
Old May 8, 2005 | 02:06 PM
MDeezy's Avatar
I flossed the hell out of mine, and it started to come off where I could use my fingers to pull it off. Dental floss works but you'll be using a lot of it cause its not that strong.
My floss was Waxed and minty
Old May 8, 2005 | 02:15 PM
Puppetmaster's Avatar
Floss... followed by Goo Gone and then wash the area thoroughly when you're done... if its cool out, ya might wanna warm it up by using a hairdryer or something to soften the glue before flossing....
Old May 8, 2005 | 02:19 PM
NCSU_MAX's Avatar
Maximoneypit
fishing line
Old May 8, 2005 | 02:33 PM
2 Da Max's Avatar
floss with bug and tar remover, and heat gun
BobMax
Aug 15, 2015 12:35 PM
Superbform
Aug 11, 2015 08:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
13Maximasv
Aug 7, 2015 10:56 AM
