Alternator help!! 96 SE maxima Brake and Battery light on
My brake light and battery light have been coming on and the volts have been spiking out to 17.5 when I drive on the inerstate and then get on the off ramp and the rpm's go down to idle, so I just had my Alternator rebuilt on my 96 se maxima and both my brake and battery light are on. I put a volt meter on it and it's putting out 15.4 volts. Since that I took it back to the shop and had the guy test it and look it over again. At his shop it puts out 14.4 volts. Then I re-intalled it in the car and it puts out 15.v volts. He says I have a bad wire that tells the Alternator when to charge. Can anyone shed some light on this deal. I really like to fix the problem and I don't want to take the Alternator back out. This is the 3rd alternator that I've had to put in the last 10k miles. Do I have a bad relay?
http://forums.maxima.org/showthread.php?t=72447&page=2
Read last post.
Read last post.
I tested it with a volt meter and test light the fuse is good. What gets me on this whole deal is the alternator was working fine @ idle before I had it rebuilt now that I got it back it's not working @ idle. My battery and brake light were not on before I had it rebuilt it was spiking when I drove for a long at high speeds then went down to idle. I'm about to pull all my hair out of my head. I also pulled the battery cables when the car was running , the car stayed running but died when I turned the headlights on. Now I did the same test on a honda almost the same year and it didn;t stall.
Superbform
Aug 11, 2015 08:10 PM
