98 Maxima Battery & Brake light come on Intermittantly
Old May 8, 2005 | 03:07 PM
billy bronco's Avatar
Brake light and battery light come on for a few seconds. Is my alternator going. Seems to be affected by turning thing on and off. Its been a super wet weekend around here, could be dampness ????
Old May 8, 2005 | 03:09 PM
MaximaSE96's Avatar
Maxima Owner
alternator
Old May 8, 2005 | 03:10 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=72447&page=2
Look at last post
Old May 8, 2005 | 03:26 PM
Okay, I found this topic: OMG The battery and brake light came on at the same time
ALT fuse has blown. It is located under the hood in the fuse box near the battery. In most cases this means your Alternator is dead/shorted out. Replace the fuse when you replace the alternator.
Is the Alternator dead or intermittant? Why does the thing flash is is on it way out? Can I just replace the fuse if blown or will it just blow again?
Old May 8, 2005 | 03:33 PM
Kevlo911's Avatar
Kevlo for President
Remember, it blew for a reason. Your alt is most likly dead. Have it tested at Autozone for free.
Old May 8, 2005 | 03:35 PM
These things are not cheap! $160 at AZ
Old May 8, 2005 | 03:50 PM
What does this fuse look like or what is it labeled? I see no blown fuse. There are a few big boys in there I assume its one of those like 165 watts maybe?
Car shows 11.5 volts not running and head light on, while running shows 13.5 volts of course the idiot lights are out. So maybe aternator is working intermittantly?
Kevlo911's Avatar
Kevlo for President
It is lableled ALT, I think its 10amp?
Old May 8, 2005 | 04:10 PM
If it was blown I would not see 13.5 volts at battery I would think, right?
Old May 8, 2005 | 04:48 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
its your alternator .. since you have a '98, you may be eligible for a free alternator replacement since there's an alternator recall for '97 & early '98 Max's
Old May 8, 2005 | 06:34 PM
FR8RFLYR's Avatar
I bought my 98 used with 55,000 miles, had the alternator fail (bearing) at 61,000 and it was not covered by the used car warranty. I'll be pretty torqued if I find the used car guy ripped me when I could have had it done free. Is there a list of recalls someplace I can consult? Otherwise, I know you call the dealer and give them the VIN and they will tell you what you are eligible for.)
Old May 8, 2005 | 06:36 PM
the recall covers '97/'98 Max's manufactured b/w 2/97 thru 2/98 .. mine was 1/98 so I had to replace mine, prob. be a good idea to check your driver doorsill for the manufacture date
Old May 9, 2005 | 02:57 AM
This morning battery was dead as dead can be. The light came on yesterday for the first time intermitantly and nothing was left on all night. Why a dead I mean really dead battery today? I have the charger on it now.
Old May 9, 2005 | 03:07 AM
Dealer did yours for free?
Old May 9, 2005 | 03:50 AM
Do you think a bad battery with a shorted cell could show same symptoms. Its not taking a charge and if I put my meter on it voltage drops quickly once charge is pulled off. Seems strange battery went completly dead over night.
Old May 9, 2005 | 04:02 AM
AllMaxxedOut's Avatar
I had my alternator & tranny replaced due to a recall on 98's back in 2002. But the alternator seems to be what's triggering the blown fuses. Is there a slow start? The alternator is trying to get juice and probably drained battery. Like someone said though, Autozone (or a R&S Strauss) will check it out for free. Check w/ your dealer as it should be covered under you warranty.
Old May 9, 2005 | 04:25 AM
Only could get started by replacing battery. Alternator is putting out 20 volts and lights are on pemanantly. Will this 20 volts cook other stuff like the computer? I think it cooked my other battery. I'll call a dealer now.
Old May 9, 2005 | 07:31 AM
This vin not on recall - go figure and I see the Alternator was replaced at least once before.
Old May 9, 2005 | 09:39 AM
Can anyone tell me what exact fuse is in question here? What is it labeled, I can't find it, thanks.
Old May 9, 2005 | 09:43 AM
yep! I replaced mine when the recall 1st started in '02
Old May 9, 2005 | 09:50 AM
Sentinal's Avatar
Same thing happened to me. They both flashed maybe 4 times. Two days after having my UDP installed, it was pouring (rain) I think it had to do with my passenger side going through a puddle at 20mph, and my belts getting wet. It hasn't happened since then.
Old May 9, 2005 | 10:47 AM
Well I had to pay $219 at AZ, its in and working okay at this point. Just would like to change the fuse in question. Where is it?
Old May 9, 2005 | 12:38 PM
navsmax's Avatar
yeah were is the fuse i jst had a brand new alternator put in as well its working good but i wanna change the fuse as well were is it located
Old May 9, 2005 | 05:13 PM
Nobody seems to know about the mystery fuse. Mine seems to be working fine too after installing re-built, wasn't to hard to do.
Old May 10, 2005 | 04:03 AM
anyone ???
Old May 10, 2005 | 08:09 AM
maxlauj95's Avatar
Yeah...where is that mistery fuse...? Post or PM me if any one know where this sucker located...I have my ALT rebuilt and working so far.... 6 months now...and would like to changes the fuse too.
Old May 10, 2005 | 04:56 PM
CleanMAX98's Avatar
where is this phantom fuse!!!!!!!!!!!!!!!!!!!
Old May 11, 2005 | 07:06 AM
maxlauj95's Avatar
Got a good looks yesterday evening and that mistery fuse is located on the box near the battery the "My 95 max" fuse is 7.5 amp on the right in the middle of the box. It should label it as ALT. S....in case any interested...Good luck
Old May 11, 2005 | 03:23 PM
CleanMAX98's Avatar
my fuse is fine and the lights are still on, they have been on for two months now and it puts out 13-14 whatever they are (amps/volts)
Old May 11, 2005 | 06:06 PM
My lights were on intermitantly for one day. That night the battery went completely dead and alternator was putting out 20 volts once I got the car started again. Since I put in rebuilt alt and charged up battery all seems fine the last few days, no lights.
Old May 11, 2005 | 08:41 PM
gatorade's Avatar
My 98 max has recently had mad problems with the lights coming without reason.
03VQMAX
Sep 25, 2015 04:19 PM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
RealityCheck
Aug 5, 2015 06:18 AM
