reluctant start
Old May 10, 2005 | 01:33 AM
evil_spork's Avatar
reluctant start
cold outside and warm outside. cold engine or warm. the engine just seems reluctant to start sometimes. it will crank a few times then it will start but it sounds very weak. i dont think a "weak start" really exists but that describes it.
any ideas?
on a side note, it pulls to the left a little on the freeway. balance seems ok. ive been up to 128mph and it was very smooth and solid, but at normal freeway speeds it has a slight left pull.
Old May 10, 2005 | 12:09 PM
evil_spork's Avatar
wow 12 hours and no one knows whats up with my car? :O
Old May 10, 2005 | 01:08 PM
SPiG's Avatar
SomePsychoGuy
It is probably an electrical problem or possibly the starter. More than likely your battery or alternator is going bad.
Old May 10, 2005 | 02:10 PM
evil_spork's Avatar
uhg arent alternators really freakin expensive?
i'd be more inclined to say battery.. its probably 10 years old lol
Old May 10, 2005 | 02:19 PM
killerVQ30DE's Avatar
Pickup a Haynes manual for $20, the troubleshooting section has various symptoms and explains what to check to fix ( and then full instructons on fixing it). Amazing value, you'lll use it all the time!
Your problem is defintely described in the troubleshoot section of the haynes manual
Old May 10, 2005 | 02:24 PM
wikidminds's Avatar
check your spark plugs. if u havent changed em in a while i recommend sticking with oem spark plugs which are the ngk iridiums if im not mistaken. theyre ten bucks a piece but well worth it.
when i changed my plugs the cold staart problem went away.
Old May 10, 2005 | 03:54 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
you're in CA. Go to autozone and have them check your alternator and battery for free.
Old May 10, 2005 | 03:58 PM
SPiG's Avatar
SomePsychoGuy
OEM is ngk Platinums. Most go with NGK coppers since they are a lot cheaper, and are supposed to perform a little better buy don't last as long.
It doesn't sound like spark plugs but that is possible.
Old May 10, 2005 | 06:43 PM
Ftaylor's Avatar
similar problem as Evil Spork
I am having the same problem as Evil with my 95 Max. Won't start from time to time, very intermitant; it will start after it gets a jump start. Took it it dealer then ran codes and said it may be an knock sensor, what ever that is and replaced it, very expensive, same problem. Ran codes again and they said oxygen sensor may be bad, again very expesive. I did not replace yet. Could it be something else a novice can fix at home?
Old May 11, 2005 | 02:06 AM
evil_spork's Avatar
could be a weak battery. not giving the starter enough juice? :shrug:
any links to a haynes man. online?(to buy) i havnt a clue where to get one around here.
ill swing by autozone, i might grab a heatercore for my comp while im at it.
Old May 11, 2005 | 02:36 AM
http://www.amazon.com/exec/obidos/AS...5858882-511341
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
