Emissions Spec – Factor of Y-Pipe Noise “Bees in the Can”
I’ve read a lot of posts on Y-pipes, different brands, different year cars,
Regardless of brand, I hear stories of some people have a “bees in a can noise”, and some people with no problems.
I’m trying to figure out whether it’s the Y-pipe, or the Spec of the car that causes this issue.
So basically what I’m looking for is:
Cali Spec + Y-Pipe = (Noise / No Noise)
Fed Spec + Y Pipe = (Noise / No Noise)
People seam to blame the brand, or are just plain puzzled on why their specific car may have noise. It maybe a factor if the Y-Pipe eliminated both precats and the noise just a result.
Only 99-00 have a difference between the cali and the fed spec Y pipes. 95-98 all have the same design of y pipe without the larger front precat which is closer to the fed spec. 01+ have the larger precat and are all cali spec. 99-00 have either one depending cali or fed spec.
I doubt the bees in the can noise has anything to do with the emission spec. It has a lot more to do with the quality of the flex section and the condition it is in.
But don’t 95-98 that are cali spec have one precat that the y-pipe doesn’t eliminate.
95-98 Cali Spec Maxima’s have one precat on the header before the ypipe. (at least this is what I found searching old posts of the topic.
I’m just trying to determine if this had an influence on the sound created by the Ypipe
Originally Posted by FAQ's
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
Credit: Daniel B. Martin
N = Canada
V = California
I also have bees in the can and I have a budget stainless Y-pipe fed spec wich was not suppose to do that noise....I'm really disappointed with that noise....it sucks!
otherwise, the power is great and I enjoy it..!!
J-P
J-P
I've had mine wrapped for a while. I wrapped the flex at first, but there were still some upset bees in there. I then wrapped the whole thing and that really helped a lot.
Originally Posted by 3jays2max0
How can you tell if you got fed or cali spec?
Originally Posted by jp_cout
where did you buy that wrapping stuff??? for how much?
thanks!
thanks!
