All clear tails
Old Oct 9, 2000 | 05:53 PM
wesley
I dont care what anybody says about trying to look like hondas or acura but I think that all clear tails on a max would look nice. I know they sell clear tails for the outside part of the light, but not for the trunk. Is there any way to take the trunk light out and custom make it clear??????
Old Oct 9, 2000 | 06:23 PM
brandonj's Avatar
It has more to do with safety than with imitating other cars. I have never seen clear brake lights on a car that were even half as visible as red ones. As someone who got rear-ended and then spent the next year with a headache (plus the fact that my car will never be the same), I can tell you that you want to try as hard as you can to make sure no one hits you. Plus, if I had clear tails when I got hit, I'd be out 8-10 grand right now instead of State Farm, because they are illegal. Just food for thought.
Old Oct 9, 2000 | 06:24 PM
MaxiPad96's Avatar
To my knowledge no, but here is what you do.. order the set of outer clear tailights.. for the section left red in the inner-trunk part of the tailight, go down to your local sign shop, or the place where you order all of your stickers and get them to order you crystalline clear sticker.. then put a few layers of this, probably two over the red section and use a razor to cut it perfectly this will give the appearance of a clear tailight, but for alot cheaper.. i did this to my bumper lights and it looked great.. i have friends with 99 civics that have done this to clear the top portion of there tailights and it looks good too..
Old Oct 9, 2000 | 07:10 PM
TexMaximum's Avatar
I agree with brandonj. Plus, YOU WILL get pulled over alot! A few months back, a guy on his way to court, got another ticket fot his clear lights. I think the half red, and half white look the best and they are much safer.
[Edited by TexMaximum on 10-09-2000 at 09:47 PM]
Old Oct 9, 2000 | 07:30 PM
wesley
How about light bulbs
If I have the clear brake lights and put red light bulbs, is that illegal? By the way, I was in a serious accident a few months back so I know what you mean.
Old Oct 9, 2000 | 08:27 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Re: How about light bulbs
when you do that, the light still doesnt look red at night. its more of a faint pink. its still illegal too, at least in CA it is. the legal code here states that we must have red on the tails. hell cops will even pull over people will altezza style lamps and tell em its illegal.
Old Oct 9, 2000 | 08:34 PM
RuMax96
I agree w/ texmax, clear and red are super touring style, that's the way to be.
Old Oct 9, 2000 | 09:10 PM
ChiTown Max's Avatar
Personally, I think red/clear looks better than all clear taillights. I have the red/clear setup, and I've seen another Max with all clear, and that just doesn't match the car. Just my 2 cents though.....
Old Oct 9, 2000 | 10:36 PM
Romeo's Avatar
here's the deal
when looking at a car from the side, it needs to reflect red in the back and orange in the front. when looking from behing, it needs to reflect red. so that is why having clear housing is illegal flat out. the light issue is also true. what you can do is get the red LED 1156 bulbs and plug those in. they give a pure crystal red look so that it is a clear visible red not a dirty pink. what i'd do is leave them on all the time when you are driving, regardless of day or night. when you park, it'll be clear and you'll be ok.
but if you really want to make all clears, here is a way, but i in no way take responsibility if anything goes wrong or if you get a ticket or whatever.
1)get a heat gun and start heating the glue that holds the housing to the lense. once it's hot enought, pry it apart.
2)get some of that plastic sheeting that is used for drop ceiling lighting. make sure you get a really strong durable grade though. i know a guy who used plexi glass. you need to use the old lense as a guide. you can form the plastic in your oven. once you get an over lay, mark it off and trim.
3)get some strong *** adhesive and glue it on. make sure you seal it up really good.
that's sort of how you do it in a nut shell. you can use your imagination on how to actually do it. i made a set of clears for my taurus (yeah, that's right, a taurus) for the hell of it. there's actually a film spray you can get for $40 a can that will spray right on. just clear coat it and it looks phat. did that to my old truck.
Old Oct 9, 2000 | 10:52 PM
wesley
If I make all clears and have the red lights and it shows red on the side and the rear will it be illegal? Why can't I use the original housing and just remove the red? Where would I get the plastic sheeting? Home Depot? How much would I need?
Old Oct 9, 2000 | 11:15 PM
Zprime's Avatar
umm..I vote no...
no no no...
all clear just means trouble....
putting red bulb will just make the ray pinkish..
remember you are trying to pass red ray through "clear plasti" that is actually whiteish
go figure red + white = ......
I want to have half red half clear
that is clean
but all clear...man that is bad.....
Old Oct 10, 2000 | 12:29 AM
Romeo's Avatar
ok
red LED bulbs give a true red look. that's why they are LED's not regular glass housing bulbs. if you run with them on all the time, you should be ok because it'll be lit. but be warned, the moment you park your car and somebody hits you from behind or if you park it on the street and someone hits you, it's your fault because you do not have the proper reflectors. as for the plastic, any hardware store should sell it. just make sure it's strong enough to hold up to everyday wear and tear. no, the original pieces are colored plastic not clear plastic with red lining. that's why we can't mod our own tails but '97 to '99 can take out the yellow with a heat gun.
Old Oct 10, 2000 | 12:34 AM
wesley
how much are the LEDs
Old Oct 11, 2000 | 07:54 PM
wesley
Clear Tail Lights
Do you have the pics of your taurus that you sprayed the clear film spray on? I would like to know how it looks. Where can I find the LED brake lights and how much would they cost? If Honda's and Acura's can use the clear tails and replace the bulbs with no problem, why can't I?
Old Oct 11, 2000 | 09:07 PM
TexMaximum's Avatar
I clears are "fugly" anyhow, and not safe. But hey, do what you want, its your car. I don't know of anyone that makes them. I think you will have to produce these things yourself.
Old Oct 12, 2000 | 10:28 PM
wesley
Final Thoughts
When I make my all clear tails and everybody is envious you can all kiss my a$$. Just kidding. Thanks for your opinions, I don't know if I'll try to do that anymore.
Old Oct 13, 2000 | 12:20 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
there's a white Maxima that goes to my skool and parks near my friends and i. he has the clear tails, but only the outer ones, they look SOOOOOOO ugly. its hella embarassing cause everyone sees it and laughs at me cause its another Maxima owner. its like the bad rep thing. Friends see that Max and then will think other Max's got bad tastes and stuff...
Old Oct 13, 2000 | 07:32 AM
Cumalot's Avatar
I don't get it, what's wrong with clear tail lights? I got clear tails on my '96 Maxima, so does this means I'm a riceboy? Just because some of you don't like how it looks doesn't mean it looks stupid. It's not like we are putting up double decker type wings on our Maximas, and with stickers all over the place. And I think clear tail lights are only available for the outer lights anyway. Personally, I think we Maxima owners are far from ricey as some Honda/Acura owners. We are quite classy IMO.
Old Oct 13, 2000 | 02:35 PM
TexMaximum's Avatar
Do you have a picture of your clear tail lights?
Old Oct 13, 2000 | 02:54 PM
Shingles's Avatar
The missing moderator
Re: Clear Tail Lights
Sorry to jump in late on this, but they CAN'T use it and have no problems. Why do you thinkt hey don't have problems? Jut cause there are lots of idiots that do that doesn't mean they don't have problems. Oh BTW, your insurance will drop you so fast if they fidn out you had those clears and got in a wreck.
-Shing
Old Oct 13, 2000 | 02:57 PM
Shingles's Avatar
hahaha, just you wait... first it's the clear tails, what makes you think no maxima will decide to put on the wings and teh stickers?
Oh and it's not about the looks... it's about safety... maybe you don't care, but I promise you, when some one nails you from behind and you have clears, you will get the ticket.
-Shing
Old Oct 13, 2000 | 03:29 PM
TexMaximum's Avatar
Hey, I don't agree with it, and think they are "fugly". I just want to see them to confirm my thoughts.
Old Oct 13, 2000 | 05:05 PM
RuMax96
I agree, clear tails are ugly, and they are played out. Also, I live in Florida and if you ever get hit in the back, it's a not at fault accident, no matter what supposedly so i wonder what would happen w/ gay clears?
Old Oct 13, 2000 | 08:15 PM
Cumalot's Avatar
Well, if you think it's ugly, it's your opinion. As far as you know, someone might think your car is ugly. And as far as someone hitting me, I do have the red bulbs. No, they are not pinkish either. I don't know where the others get their bulbs, but my bulbs are really red. Unless you're blind, you could see them. So, what do you consider as non ugly? Stock? If clear tail lights are ugly, I guess you would consider people with clear corners ugly too, huh? Come on, it's just a matter of taste. Like I said, you might think clear tail lights are ugly, but someone might think that generally fixing up a Maxima is rather stupid. I know some people that said that before. Like the saying goes whatever floats your boat.
Old Oct 13, 2000 | 08:43 PM
TexMaximum's Avatar
More like a matter of bad taste. I still think it will cheapen your car. I really want to see it though to give an honest opinion.
Old Oct 13, 2000 | 10:13 PM
max95q's Avatar
He didnt say that the bulbs were pinkish. He said that red bulbs+ clear or whitish tails = pinkish color giving off. I ve seen it too. on some cars you can barely see the red bulb or it is a pinkish color that the light gives off. They look good on some cars , but the max is a classy car, red/ clear is the way to go. If I had a 95 or higher max Id go with the red/ clear, unfortunately I have a 2nd gen.and they dont make applications for my car I even asked just to ask about a year ago. But its extremely rare to see the red/clear combination and it looks really great on all the Maximaz.
Old Oct 13, 2000 | 11:15 PM
Turbo95Max's Avatar
well true, its mainly personal taste, but if you only get OUTER clear...thats UGLY, no matter personal taste or not. YOu have part stock, part clear....might as well keep the orange sidemarker but clear blinker when you do your front clear bumper lights. See if that looks wack? at least clear out the whole trunk lid.
Old Oct 14, 2000 | 10:41 AM
Cumalot's Avatar
Well, I only have the outer clear because I think they're only available for the outer, nothing I can do. I know that some red bulbs + clear = pinkish. However, I don't know about the other people, but mine is really red. When I stepped on the brakes, my friend driving behind me told me it was really red, kind of like if I had the stock lights. Now I know why they costed so much. I don't know, maybe I will go the route of half red and half clear. Specially, if I get my kit.
Old Oct 14, 2000 | 09:13 PM
nismomaxse97's Avatar
I got behind a civic 4 door with clears and the only red I could see was from the brake light inside the back window.
He had two pieces of red reflector tape on the housings, I guess so he thinks it is legal or something. I eventually pulled up next to him and he had been hit on the back right side. Coincidence maybe. Stick with stock, red white combo or altezza for safety.
Old Oct 14, 2000 | 09:15 PM
96BLUMAX's Avatar
Do you guys like the custom red/clear that match the inner part? I think that looks good. But if you are talkin about the total clears, I agree with you.
Old Feb 18, 2001 | 12:47 AM
wesley
Anyoone Yet?
I have the clear outer tail lights on my 95 now. Has anyone tried to clear out the red piece of the inner tail light. I have had suggestions of forming a new clear piece and replacing it with the clear/red. Does anybody else have a better idea?????? If anybody has it or has pics can i see them
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
