car wont start
car wont start
after work on friday, car wouldnt start. kept cranking the engine and finally started after 15 min. pulled codes on camshaft position sensor circuit (0101) fault and knock sensor circuit fault (0304). got home, turned the car off and it started right up several times, so i cleared the codes. the next day it did the same thing again, but only threw out the camshaft code. i pulled out each spark plug and none was triggering. tested the coils and all are fine. tested the sensor but didnt get any readings with the ohm meter. read up on other threads and found similar problems but not exact as mine, and all related the a bad sensor. i hope this is my case cause im about to spend $70 on a new one. is the knock sensor code caused by the camshaft code? any input would be appreciated..thanx
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
Maxboy23
08-11-2015 11:59 AM
