why is it that all STS look the same?
Old May 16, 2005 | 11:56 PM
maximazation's Avatar
if you look at any STS shifter installed on the 4th gen, it all looks the same. they all look closer to the shifter trim in a forward position, why did the companies design it like that?
BTW: its been over 700+ posts and i finally donated...
Old May 17, 2005 | 12:48 AM
NISMOPower's Avatar
I wondered the same thing, My B&M hits my trim in 3rd gear.....
Old May 17, 2005 | 01:10 AM
my custommaxima.com STS hits the trim in 1, 3, and 5th gear...
Old May 17, 2005 | 03:19 AM
SPiG's Avatar
SomePsychoGuy
B&M and most of the STSs were not designed for our cars. Most FWD Nissans until around 2002 or so had the same shifter design. Thus if you make the shifter for one car; it works for all of them. The B&M was designed for the G20. Since the Sentra and 200sx are all on the same platform, they don't have a problem. One thing that does change throughout the FWD Nissan cars is the angle the shifter rod is bent. Since it doesn't vary a ton they weren't going to try to produce a different shifter rod for every different angle and every different car. It is nice for them to be able to keep it as universal as possible.
Most of the other shifter companies either copied some elses design, were still designed for the sentra, or if they were actually designed for the Maxima then they just didn't take enough time to properly design it to not move the whole shifter forward.
Old May 17, 2005 | 07:35 AM
MrEous's Avatar
^ Jeff™
Put some washers under the front bolt of the sts base mount...that'll help.
(I do not condone any such action in any way...)
Wolvee
Aug 11, 2015 12:24 PM
amb4081
Feb 23, 2002 12:02 AM
Victim64
Dec 7, 2001 10:49 AM
deathwish
Nov 14, 2001 02:56 PM
hawkdog
Apr 22, 2001 04:52 PM
