How to tell if your strut mounts are shot?
Old May 17, 2005 | 08:27 AM
Seximus Maximus's Avatar
Are my strut mounts shot??
I keep hearing a knocking/clunking noise in the area of my rear passenger side wheelwell when i go over bumbs and curbs mainly. any ideas?
Old May 17, 2005 | 08:49 AM
njmodi's Avatar
Do I get a tax break?
One thing I've read suggests: open your hood and bounce the car up and down on - look for any movement near/of the strut mount. If it moves, the mount is bad. I've never used this method, so I can't vouch for its accuracy - but it makes sense.
Old May 17, 2005 | 09:03 AM
SilverC5's Avatar
My front mounts are shot. If you look at the springs and have someone turn the wheel you can see the tension build and then release, causing the clunk. It's really annoying. It should be an easy fix. If I could just find the time.
Old May 17, 2005 | 09:05 AM
njmodi's Avatar
That is not the mount that is shot. In your case the problem is the strut bearing - this is a common failure on the 4th Gens. The parts are cheap (15 bucks per side), but you have to pull off the entire strut/spring assembly to replace the bearings.
Old May 17, 2005 | 09:09 AM
SilverC5's Avatar
My bad. I thought the bearing was part of the mount kit. Thats what advance auto told me when I called for pricing.
Old May 17, 2005 | 11:41 AM
I dont know if it matters but i have illuminas and Tiens H-techs i have had for about 8-9 months. installed by a local suspension place. just thought id mention that i have aftermarket suspension, in case it matters =P
Old May 17, 2005 | 12:23 PM
86maxima96's Avatar
I Broke OT
...don't drive over curbs??
Old May 17, 2005 | 12:28 PM
I ment the little incline that goes up into parking lots or gas stations etc... =P
so anyway any ideas what the problem could be? mount, bearing, loose bolt, gremlins, etc....
Old May 17, 2005 | 02:35 PM
quaker's Avatar
I'd start by looking for a loose bolt at the top of the strut tower, the 3 mounting bolts and the center -strut retainming nut. Also shake the car up and down while viewing the retaining nut.If it move around its most likely the strut mount. Then take the wheel off and inspect the condition of the sway bar bushings and end links.
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
