Car warms up...starts to whine
Old May 17, 2005 | 10:55 AM
VOX98's Avatar
Ok so I'll start my max...drive it for a bit and then I get this awful whining noise in the front end. It is pretty constant, gets higher with engine revs BUT here's the catch...when I move my steering wheel at a dead stop...that's when it's the worst.
It's so loud I have people giving me wierd looks. What the hell could this be? Power steering pump, alternator? What?
Old May 17, 2005 | 10:58 AM
njmodi's Avatar
Do I get a tax break?
Could just be a belt...get someone to turn the wheel while you listen carefully for the source of the noise... should be easy to identify since it happens while the car is still..
Old May 17, 2005 | 02:35 PM
hacim105's Avatar
It is one of your belts. Check those for cracks or other wear on them. and replace as necessary or even if you don't feel it's necessary.
Old May 17, 2005 | 02:42 PM
quaker's Avatar
One more vote for the belts.
Old May 17, 2005 | 03:04 PM
adithius's Avatar
Do you have steering fluid? My wifes Audi had a whinning noise, and it turns out that the fluid was low. Try replacing the fluid too.
Old May 17, 2005 | 03:30 PM
CreativeDesignz's Avatar
the fluid just doesnt evaporate...if u are low on fluid u probably have a power steering leak, and check ur belts as well.
Old May 17, 2005 | 04:35 PM
Max1man's Avatar
definately belts
Old May 17, 2005 | 04:37 PM
el_muchacho_qc's Avatar
Check belt, streering fluid level. If not, might be power steering pump bearing. Good luck!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
