ECU Code p0150 (0303) and knock sensor code
Old May 19, 2005 | 02:07 PM
Umass021's Avatar
I need to replace my front left bank o2 sensor and my knock sensor. Does anyone know where there located and where is the cheapest place to get them? What will happen if I drive with those sensor's blown?
Old May 19, 2005 | 02:17 PM
NmexMAX's Avatar
dot dot dot ...
Your car will implode with you in it ... and you will not live ..
Read the stickys please. It's ALL in there. Nothing bad will happen besides bad gas mileage/poor performance, there's a lot of info in the stickys, i.e. it might be one or the other sensor or jsut the O2, so read the stickys please please ....
Old May 19, 2005 | 02:18 PM
Loe max's Avatar
0303 is the O2 sensor on the front bank. The KS is located inbetween the V below the intake manifold.
Old May 19, 2005 | 05:46 PM
nismos14's Avatar
§è~® f®ÈÄk
that o2 sensor is the one furthest forward on the y
Old May 19, 2005 | 11:54 PM
Umass021's Avatar
Where can I get a cheap one?
Old May 20, 2005 | 06:50 AM
nismos14's Avatar
§è~® f®ÈÄk
www.oxygensensor.com
Old May 20, 2005 | 09:25 AM
NmexMAX's Avatar
dot dot dot ...
forgot the "S"
www.oxygensensors.com
Old May 20, 2005 | 02:32 PM
Umass021's Avatar
Do I need to get both o2 sensor's?
Old May 20, 2005 | 02:59 PM
nismos14's Avatar
§è~® f®ÈÄk
i would probably go ahead and replace all three, as the others will probably go bad soon as well.
Old May 21, 2005 | 08:37 AM
Umass021's Avatar
Is it bad to replace one at a time?
Old May 21, 2005 | 08:56 AM
nismos14's Avatar
§è~® f®ÈÄk
No its not but you may still get the code after replacing only one.
Old May 21, 2005 | 04:52 PM
Umass021's Avatar
It said only one was gone. What should I do first the knock or the o2?
Old May 22, 2005 | 11:03 AM
Umass021's Avatar
What should I get first?
Old May 24, 2005 | 10:34 AM
Umass021's Avatar
I reset the codes and my light hasn't come back on since. Should I still replace the o2?
Old May 24, 2005 | 11:00 AM
nadir_s's Avatar
vicodin ... gift of life
check to see if your knock sensor is working or not. The instructions are in the FAQ on hwo to check the sensor with a voltmeter.
Then, you better jump on this deal for 79 shipped becaus that's the cheapest i've seen yet and it's an OEM sensor from Pinnacle Nissan.
http://www.trademotion.com/partlocat...49&catalogid=0
Old May 24, 2005 | 02:18 PM
Umass021's Avatar
I am talking about the code for the o2.
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
ballerchris510
Sep 23, 2015 08:46 PM
