Is this true about a VB modd?
Old May 20, 2005 | 02:20 PM
icedout's Avatar
so i heard when you get the vb modd putt in you have to give it 500miles to fully break in.The ecu has to get used to the new modd.
is this true guys just wanted to know thinking about doin the modd.
Old May 20, 2005 | 02:27 PM
NmexMAX's Avatar
dot dot dot ...
Who told you that It's false, drive it like you normally do with no special treatment, unless you're super paranoid
Old May 20, 2005 | 02:30 PM
icedout's Avatar
jeff at maxium tunning said that
Old May 20, 2005 | 03:08 PM
2 Da Max's Avatar
so if Jeff told you this why would you ask??:
Old May 20, 2005 | 03:10 PM
NmexMAX's Avatar
dot dot dot ...
He didn't tell me that ...
Old May 20, 2005 | 03:15 PM
njmaxseltd's Avatar
I find that hard to believe.
A valve body doesn't break in, and the ECU doesn't control the tranny.
Old May 20, 2005 | 03:21 PM
NmexMAX's Avatar
dot dot dot ...
It shifts all hard all the time whether you want it to or not. The TCM controls the tranny. And what they do has nothing to do with the TCM, only mechaically. But if you do get it, enjoy, and get a VI + Extende rev limiter b/c w/o the limiter it will shift quite fast therefor leave you in a dead spot in the next grear.
Old May 20, 2005 | 03:28 PM
2 Da Max's Avatar
ecu only adapt to electronical things not mechanical things and moving parts.. lol i dont think that made snese
Old May 20, 2005 | 03:57 PM
Ninos_Maxima's Avatar
be the change u want2C
After reading this I have a question
wheres the TCM located?,
Old May 20, 2005 | 04:02 PM
THT's Avatar
THT
Throbbing member
Under the center console, just in front of the ECU.
Old May 20, 2005 | 04:03 PM
2 Da Max's Avatar
is it by the ecu? i know the bcm is behind the radio...hhm
Old May 20, 2005 | 08:07 PM
THT's Avatar
THT
Throbbing member
I thought the BCM was by the trunk?
TCM is right under your radio/CD player.
Old May 22, 2005 | 10:17 AM
icedout's Avatar
ok thanks guys for the info maybe i just misunderstood him,but yea iam thinking about gettin it with a tranny cooler,what do you mean leave me in a dead spot in the next gear?
Old May 22, 2005 | 10:23 AM
NmexMAX's Avatar
dot dot dot ...
When driving with a stock VB there's a little slipappage leading you to be in a slighter higher RPM when the next gear engages, most notable in the 1-2 shift, leaving you about 4.4k (stock). The VB mod quickens the process and leaves you about 3.8-4k which is a little low considering how tall the gears are. One thing to consider, extended rev limiter.
Old May 22, 2005 | 10:31 AM
icedout's Avatar
how can i get an extended rev limiter i have a 99 max so no ecu upgrade,any type of piggy back system you know of that would do it?
Old May 22, 2005 | 10:40 AM
NmexMAX's Avatar
dot dot dot ...
SOL there bud ..
Old May 22, 2005 | 11:13 AM
icedout's Avatar
SOL.??whast that mean?
Old May 22, 2005 | 11:52 AM
RA030726's Avatar
I'm nutty for Nissans
96 ecu works in a 99
Old May 22, 2005 | 12:27 PM
icedout's Avatar
is that so,very interesting
Old May 22, 2005 | 04:21 PM
eckohb's Avatar
yup, ECU is now available for an additional 50 bucks for 99s. I noticed that dead spot in the rpm when using my DR. I got faster times w/o it, but faster speeds with it. Extended limiter here i come. Oh yeah, SOL means **** out of luck
Old May 22, 2005 | 04:26 PM
paultyler_82's Avatar
and as always us 98 owners are pretty much SOL when it comes to a workable ECU solution.
For those 98 owners out there, I'm working on comparison study between the older ECU's and the 98 ECU's, but unless I have a little better idea of what it is JWT is doing to work their magic, my research is pretty much useless. Can anyone give me an idea of what it is that JWT is modifying?
Old May 22, 2005 | 04:35 PM
NOCturnalI30's Avatar
Wait what about 5th gens i got that and when im driving sort of normally i experience that extreamely. before i never did. is there anyuthing i can do?
Old May 22, 2005 | 06:36 PM
95GLEPEARL's Avatar
OK so I read the article on vqpower.com about the vb mod and maybe I missed something, but it looks to me like he is just removing the vb. then putting everything back together. Someone please explain this a little better, take a look at the article and tell me if I missed something. It under DIY section.
Old May 22, 2005 | 07:33 PM
Sizzam's Avatar
i got my VB done by jeff last summer. and he told me i can use it to its full potential right away. and now, almost a year later, it is still working like he had just put it in a day ago.
CreativeDesignz's Avatar
he replaces ur stock valve body with a completely different one that is moddified before hand
Old May 22, 2005 | 07:34 PM
killerVQ30DE's Avatar
They are probably explaining how to REMOVE it for shipping to company who does the work. Not howto do the ACTUAL VBmod
Old May 22, 2005 | 07:40 PM
95GLEPEARL's Avatar
ok so were would I find a "better" vb? Any names or any specifics I should know?
Old May 22, 2005 | 07:44 PM
NmexMAX's Avatar
dot dot dot ...
You buy it already modified, all you do is put the modified unit in there, so it's a direct replacement.
And describe "better" Maximumtuning provides an excellent array of options. Stage I, II, II.5, and III. What more do you want?
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
