digital clock going on and off
Old May 25, 2005 | 08:54 PM
nissanguy8's Avatar
does anyone have the problem of the digital clock going on and off whenever it wants to??? and anyone know how much it would cost to replace it? and how I would even open that section to get the clock out?
My girlfriends 95 maxima SE is having that problem right now. I guess I should be happy that this is the only thing wrong with the car!!!
Old May 25, 2005 | 09:24 PM
fishpony's Avatar
yes i had that problem with my 4th gen. went to a junkyard and got one for $20. To take it out just stick a flathead in the gap between the climate control and the clock and pry it upwards, it will feel like your going to break it but it shouldnt. then undo the wire from the clock and there are 2 screws that u have to take off. hope this helps
Old May 26, 2005 | 12:15 AM
azmaxipad's Avatar
i have a clock perfect working order 20 shipped.
Old May 28, 2005 | 10:33 AM
nissanguy8's Avatar
hey azmaxipad, I ll let you know about your clock, what year did it come out of?
Old May 28, 2005 | 06:29 PM
jMax23's Avatar
yea mine the same way too ever since i did that digital clock stays illuminize mod. i need one too!!
Old May 28, 2005 | 06:33 PM
CFC's Avatar
CFC
My clock was out too.
I took it off; inspected the circuit board, and noticed some broken solder joints. All I did was resolder the broken connections and that whipped it back into shape.
I suspect some of you may have the same issue. If you know how to use a soldering iron (or know someone who does) give it a look first, it's pretty easy (and cheap).
CFC
shilov
Feb 19, 2024 09:40 PM
viperboy
Sep 27, 2015 07:05 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
