Clutch Problem...HELP!!!
Old May 26, 2005 | 06:26 AM
BrentK7's Avatar
Ok, so last night my clutch is working perfectly. I get in this morning. Push clutch in to start but as soon as i put my foot on the pedal that pedal pushes very very easily to the floor. Feels like the last 2 inches of pedal travel actually apply hydrolic presure to release the clutch. And then sometimes when i take my foot off the clutch it almost sticks to the floor and then pops back up, and other times it does stick to the floor and i have to pull it back up.
I would tend to think that there is a hydrolic leak somewhere and that is why it only releases the clutch at the last 2 inches. This is obviously not enough to put it into gear.
Thanks.
Old May 26, 2005 | 06:53 AM
Loe max's Avatar
Check the fluid in your Master Cylinder. Its probably empty. Just refill and bleed it and then check for leaks.
Old May 26, 2005 | 09:15 AM
BrentK7's Avatar
Ok i checked the clutch master cylinder. Dry as could be. Strange there was no puddle under the car. So i filled up to see if i could pump up the clutch. Got it to a bit where i could move the car to a different (level) spot. When i had the clutch to the floor it was disengaged, but when i would pull it like half an inch off the floor the car trys to jump forward. So i guess that means it is just barely disengaging the clutch. I am going to try bleeding the system next so that i can try to get the car to my dads house (like to do all my work there). And then i guess i need to find the leak in either the slave or master cylindar.
Can anyone give me some tips on how to bleed this system, never done it on a car before, only on motorcycles. Thanks!
Also does anyone know what a new Master Cylindar costs for a '96?
Loe Max: wow, except for the wheels we have like an identical car. Good choice. heh.
Old May 26, 2005 | 09:20 AM
MDeezy's Avatar
the process for bleeding is in the how to's its on the motorate.ca site. very easy process will need and extra foot to help you out and atleast a liter of Dot 3 brake fluid. After you bleed engagement should be smooth as silk. Adjust the grab point if its too high or low thats in hte faqs also.
Old May 26, 2005 | 09:26 AM
BrentK7's Avatar
thanks for the info man. I will report back with progress.
Old May 26, 2005 | 01:36 PM
BrentK7's Avatar
could someone help me find these directions. I have been looking all through the "how to" and can't seem to find it. thanks again.
Old May 26, 2005 | 03:27 PM
BrentK7's Avatar
nevermind, i found it. Thank for the help guys.
Old May 31, 2005 | 02:35 PM
desalphine's Avatar
Thanx guys my max is also having the same prob.. Brent is it working fine after u bleed it??
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
