I Need Major Help Now Please!!!
Old May 26, 2005 | 06:36 PM
NCSU_MAX's Avatar
Maximoneypit
i regreased my starter, put everything back on and now nothing happens when i turn the key. i have electrical but thats it. my dad says he can possibly hear the starting trying to engage but nothing is happening. i have to go to work in the morning - need help now pleeeease. thanks guys.
Old May 26, 2005 | 06:38 PM
brooklynK3Y
Too much grease? starter put in wrong, I dont know but @ your Sig..
Old May 26, 2005 | 06:50 PM
ewuzh's Avatar
Go back and check all your work. Check all connections, wires, hoses, etc... Did you disable anything (fuel pump/pressure) when you uninstalled the starter? Is anything hooked up backwards?
Old May 26, 2005 | 06:53 PM
NCSU_MAX's Avatar
Maximoneypit
i double checked everything - my dad says he can hear power to the starter but its just not doing anything.
Old May 26, 2005 | 06:57 PM
ewuzh's Avatar
Well if you don't get it solved by tonight, don't panic. You have a 5spd, so you can pop the clutch and start it that way. Just get it rolling down a hill with the clutch down in first gear with the ignition at the ON position, and then really quickly let the clutch up and immediately kick it down again to get the engine fired up.
Old May 26, 2005 | 07:03 PM
Bobo's Avatar
And park it on a hill everytime you use it until its fixed. I don't be thinking so.
Old May 26, 2005 | 07:16 PM
NCSU_MAX's Avatar
Maximoneypit
ok - i tapped it w/ a hammer several times and after a few turns of the key she fired up, but the starter still struggled engaging and disengaging. less grease or more grease!!??
Old May 26, 2005 | 07:41 PM
NCSU_MAX's Avatar
Maximoneypit
well its still struggling but working and im getting a CEL
anyone?
0407 - starter
0304 - Knock Sensor. Why?
aw11power
Oct 10, 2021 04:57 AM
Melissa40
Jun 30, 2017 10:04 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Socalstillen
Sep 20, 2015 11:46 PM
ColdCananda
Sep 20, 2015 10:45 PM
