Third blown headlight bulb in 2 years
Old May 26, 2005 | 07:52 PM
Nisman's Avatar
So I noticed on my driver home tonight that my driver's side headlight is blown. This is the third time in 2 years, on the same side. Has anyone encountered this before or would know what would be causing it?
Any insight would be appreciative.
Old May 26, 2005 | 08:08 PM
9maxima5's Avatar
funny thing mine did the same thing to the other night. Werid must be the MA weather..
Old May 26, 2005 | 08:45 PM
ImmaSquashYou's Avatar
a lot of times when a headlight bulb blows is because of electric current. when i did the 9007 conversion on mine, mine blew in like 2 minutes because i was dumb and went to an atm got money, went into my car started it, n not waiting turnmed my lights on very quickly. so i just went back to 9004 n then got new smoked cefiros n hid's anyways, start your car and at least wait till all the lights stop blinking, the brake light, gas light, everything. wait till all of that stops. wait like 3 more seconds, then turn on your headlight. what its doing is allowing all the eletricity travel to your car evenly hence minimizing a shortage which cause ur headlight to blow.
Old May 26, 2005 | 08:53 PM
JPMax's Avatar
What's next!?..
Check the bulb socket and wires. There might be some dirt or corrosion on the contacts for the bulbs.
Old May 26, 2005 | 09:26 PM
speed racer's Avatar
Why won't you just put a 30a fuse so that the fuse will blow and not the headlamp.
Old May 26, 2005 | 09:31 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I recommend using some Hospital Gloves, before installing them.
Old May 26, 2005 | 09:57 PM
ManualMaxima's Avatar
5th Gen till she dies!
what bulbs are you using? cause if it is hyperwhites or anything well that mihgt be your problem.
Old May 26, 2005 | 10:10 PM
dukelubas's Avatar
Org Lurker
I recommend simply not touching the bulb itself at all. Just take your time and be very careful.
Old May 28, 2005 | 10:28 PM
Nisman's Avatar
I usually wait awhile before starting the car.
Are you suggesting that all max owner tend to encounter this if they start without delay
Old May 28, 2005 | 10:29 PM
Nisman's Avatar
Maybe I'll giive it a try.
Old May 28, 2005 | 10:33 PM
Nisman's Avatar
I went through 2 Slyvania Silverstars and a PIAA superwhite.
I've switch the bulbs for years, since I got my car.
It's just been blowing recently.
Old May 29, 2005 | 04:56 AM
browne's Avatar
my right foglight keeps blowing too...
Old May 29, 2005 | 06:46 AM
Silverstars are known to blow after a year. You should look in the How to section for converting from 9004 to 9007. I just did this set up and am very please. It cost me all together about 45.00.
Old May 29, 2005 | 07:57 AM
CystumMax's Avatar
I have silver star for over year now, and still working.
Old May 29, 2005 | 10:14 AM
maxima_million's Avatar
Blown headlight
I was driving late at night w/my g-friend and was having a bit of fun by flashing the high beams in rhythm to some music and voila - I blew drivers side light. Glass was ALL OVER the inside of the light. I ended up replacing the bulb w/OEM and have not had a problem. I also suggest to NOT tough the bulb w/anything - just be patient when installing it.
Old May 29, 2005 | 12:05 PM
maximavqpower97's Avatar
all am thinking right now for sure is moisture.try checking for rust if its not that.clean your battery.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
