Whats the composition of the nissan OEM pads?
Old May 27, 2005 | 01:49 PM
eturnl
anyone know if the nissan oem pads are organic/ceramic/semi metallic etc?
Old May 27, 2005 | 01:55 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Semi Metallic, I think....
I recommend you buy these, You will have not regeret it.
http://www.buybrakes.com/store/HB268-665
http://www.buybrakes.com/store/HB421-622
Old May 27, 2005 | 01:56 PM
MaximaSE96's Avatar
Maxima Owner
i thikn they are semi-metallics
Old May 27, 2005 | 02:01 PM
Fork's Avatar
Maximaler Experte
I can confirm, Nissan OEM pads for the 4th gen are semi-metallic.
Old May 27, 2005 | 02:05 PM
eturnl
well according to 'just brakes' they are supposed to be organic.
Old May 27, 2005 | 02:09 PM
CystumMax's Avatar
who is "just brakes" is that some company?
Old May 27, 2005 | 02:17 PM
eturnl
Yes.
http://www.justbrakes.com/
Old May 27, 2005 | 02:27 PM
sterlingmaxima's Avatar
i use to have oem i wish i still had them i bought the furlast gold ones at auto zone sence i need brakes asap they are awful they prob stop worse
Old May 27, 2005 | 05:43 PM
Spaniard's Avatar
I second the suggestion for Hawk pads, based on the fact that the street/track pads (HP+) are fookin amazing
Old May 27, 2005 | 06:45 PM
el_muchacho_qc's Avatar
I confirm. Just installed Hawk pads with stock rotors (...sadly), and they doing a great job. Quiet and excellent brakin performance.
Old May 27, 2005 | 07:03 PM
goldtooth's Avatar
while we are on the subject of brakes and i still cannot form new threads,
i tried looking for something on drilled/ slotted rotors. I plan on getting these that u recommend by the way. Which is the best to go with ? drilled? slotted ? or drilled and slotted ? perhaps stock ? what ive heard is that the drilled rotors crack ? and i should go with slotted only?
Hopefully somebody can enlighten me on where i should go with this. Thanks in advance.
Old May 27, 2005 | 08:32 PM
Spaniard's Avatar
x-drilled are fine, unless you are going to be road racing.
Old May 27, 2005 | 09:26 PM
Maxima99SE's Avatar
will fly for food
I was told stocks are organic pads..
Old May 27, 2005 | 09:29 PM
hollaatchaboi's Avatar
I put on duralast gold pads and it sucked. if braking from a high speed, my brakes actually started smoking and sparks came out.
Old May 28, 2005 | 02:22 AM
Maxtank's Avatar
i'm running red stuff's.....they are cool for normal driving, but DIG when you slam em. I love em. They are full ceramic, big difference from stock pads with stock rotors
Old May 28, 2005 | 03:47 AM
Frank Fontaine's Avatar
I highly recommend OEM for several reasons. First, you can find them anywhere for 20% off, no tax, no shipping.
Secondly, they last. I replaced my fronts at 54k or so (98 SE 5-spd) and they were only 60% gone. I had bought the kit as well, didn't use it, and actually forgot to reinstall the old shims on one side. NEVER any squeal or groan since. Did the rears with OEM at around 89k. They were about 80% gone but crumbled when I took them out, due to age.
All in all, OEM is a guaranteed solution where there is no noise, and you know they'll last. Win-win if you ask me.
Old May 28, 2005 | 08:58 AM
eturnl
But still, does no one know what the composition of the pads are made of? the dealer doesnt even know! wtf.
Old May 28, 2005 | 09:07 AM
CystumMax's Avatar
Get slotted rotors, they going to be a little quiter thern drilled, I have the drilled one. And i am happy witht he result, deffinitly go with the hawk brake pads.
Old May 28, 2005 | 09:15 AM
CystumMax's Avatar
Well, you can waste your money on OEM, Good luck to you.
you don't know anything about Hawk brake pads...
Old May 28, 2005 | 09:26 AM
Bobo's Avatar
You shouldn't be talking to Frank Fontaine like that, he knows everything!
Old May 28, 2005 | 09:32 AM
Matt93SE's Avatar
STFU n00b!
From everything I've seen with Maxima brakes in the last few years, 90% of the problems with warped and cracked rotors point to the OEM pads.
I would highly recommend NOT using them.
street pads I would recommend:
Bendix IQ
Raybestos Quiet Stop
Wagner
Performance Friction
Axxis MM (Axxis Ultimate = track pad)
Hawk HPS. (HP+ = track pad)
unless you're doing a lot of HARD stopping on the street, i.e. severely illegal driving, then you will never run the car hard enough to need pads like the HP+ or Axxis Ultimates on the street. they will actually do more damage to the rotors because they never get heated up to their proper operating temperature... use a pad that's designed for street use and the pads and rotors will last much longer.
If you decide to go to the track, then spend the money on an additional set of track pads and swap them out when you get there. trust me, you'll save a ton of money that way.
Old May 28, 2005 | 10:13 AM
RockfordMax's Avatar
Back from the dead
holy crap!
Old May 28, 2005 | 08:46 PM
97MaximaSE's Avatar
i had Axxis mm pads and they had to be the worst pads i ever owned.....made groaning sounds, almost no braking power in the morning, ate through them in 6 months, dusted to all hell. Only decent thing about them was the braking power when warmed up which was slightly better than stock. I went back to stock pads and im on the same pads for about 2 years now, no noise, decent stopping power and virually no dust compared to the MM's. I might try the hawks out when the stock wears out but never again will i get Axxis pads.
Old May 28, 2005 | 09:06 PM
CystumMax's Avatar
Does he realy?
Are you by anychance his Spoke man?
Old May 28, 2005 | 09:31 PM
MaxGordon7's Avatar
Ya i got KVR brake pads from PDM racing. Thought that maybe they would last long time and have low dusting for a street pad with brembo Slotted/drilled. i put them on like a little over a month ago and it seems like there more than after way gone already and my wheels never looked dirtier. I think ill go back to stock, ive heard they were cremic
MAXSE5SPD
Sep 17, 2022 04:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
