CV Axles
Old May 28, 2005 | 09:57 AM
ontysx's Avatar
CV Axles
I'm fixing to go buy two new CV Axles....what would I look at to see if I have anti-lock brakes or if I do or don't have a limited slip differential...
Old May 28, 2005 | 10:57 AM
98 DBL Black's Avatar
ABS n' Stuff
I would assume if you have an ABS light come on when you put the key in the "on" position, you would have ABS. Also consider you have a GLE.
Also check the VIN with an online source. ie. some thread on this site or carfax.com
Old May 28, 2005 | 03:16 PM
nick's Avatar
99.9% you don't have LSD , only Canadian maximas had it from factory,
but to be 100% sure lift up the front end and spin one wheel, it the other one spins in opposite direction - you don't have LSD, if it doesn't spin you have LSD
olso you can look up the tranny vin number , V stands for LSD
For ABS , look for light on dashboard, and for wire that goes through rubber groomet through the frame of the car.
Nick.
Old May 28, 2005 | 04:02 PM
dgeesaman's Avatar
Maintenance Monster
Nick.
Two more ways: look at the metal tag on the passenger side of the firewall, behind the engine. There is a transmission code - if there is a V near the end, it's LSD. But that's highly unlikely for a US car.
The ABS adds a boatload of small metal tubes that block access to the fuel filter. So just between the engine and the drivers side wheelwell, you'll see a jungle of tubing on an ABS car. Make the fuel filter job a *****.
You'll also see two lines running to each wheel/brake assembly in front - a thick cable for the brake fluid, and a thinner wire going to the ABS sensor.
Dave
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
