Help getting an O2 sensor off
Old May 28, 2005 | 10:15 AM
kosmo886's Avatar
is there any trick to getting a rusted oxygen sensor off? also would a bosch o2 sensor work fine?
Old May 28, 2005 | 10:17 AM
86maxima96's Avatar
I Broke OT
do you have the O2 Socket? i picked one up at sears, i think for less than $10. works great. especally with the extra room from my Budget y-pipe over stock.
Old May 28, 2005 | 10:30 AM
kosmo886's Avatar
i am getting a soc...i know that there is probably a lot of rust though, so i was wondering if anyone had any advice.
Old May 28, 2005 | 10:36 AM
86maxima96's Avatar
I Broke OT
use some liquid wrench. spray some on, then later in the day, spray some more and try to loosen it again. keeping spraying and trying to get it off.
Old May 28, 2005 | 10:37 AM
86maxima96's Avatar
I Broke OT
you could also try torching it if nothing else. or else take it to meneike or somewhere and have them get it off for a couple bucks if you can't.
Old May 28, 2005 | 11:08 AM
Stabone's Avatar
You can also try Naval Jelly which has Phosphorus Acid. Works very well on rust, I used it on my rear 02.
Old May 28, 2005 | 12:01 PM
crazy97's Avatar
It works better after the car is warmed up and the exhaust is hot.
Old May 28, 2005 | 03:45 PM
al71469's Avatar
I just replaced two O2 sensors today. I had to get an O2 socket from Autozone and sprayed the sensors with WD40 and warmed the car up. I had a problem with having enough access with the O2 sensor at the front of the car. Depending on the height of your O2 socket, you may need to buy a short extension bar. My 3" extension bar was to long and I had to buy a 1.5" extension.
I do have a problem with installing the sensors. I have tighten the sensors per spec but I still have smoke coming out. I don't know if the smoke is exhaust smoke or from the high temp antiseizing compound. I don't think it is from the WD40; WD40 should burn off within a few miniutes.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
