Bleeding Brakes.....
Old May 30, 2005 | 05:27 PM
MaxGordon7's Avatar
Ive been doing the gravity feed way of bleeding my brakes. I remember seeing getting clear tube, putting fuild into a glass bottle. Then you put the tube on the bleeder and tube into fuild and bleed til no bubbles but, i keep getting bubbles even after about an hour or so at this. I did replace all my lines with SS brake lines, is this normal or should i just keep bleeding? Just looking for a shout out...
Old May 31, 2005 | 02:28 AM
FishyMan's Avatar
maybe your too senstive w/ the bubble thing. BUBBLES meaning actual ones that take a space in the clear tubing. not small micro bubbles in the fluid itself.
just bleed, and u should be okay. do gently..
Old May 31, 2005 | 05:40 AM
mzmtg's Avatar
Minister of Silly Walks
Make sure the tubing is attached firmly to the bleeder. Air can leak in there and show bubbles in the fluid, or worse, the air can leak back into the caliper.
Old Jun 14, 2005 | 11:58 AM
ajsilvaoc's Avatar
I do my brake bleeding the same and haven't had any problems but i also don't have any bubbles at all
rbuswell
Nov 17, 2016 04:54 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
vanebecker
Aug 17, 2015 08:24 PM
tombrown
Dec 10, 2001 10:23 PM
VQMaxSE
Mar 7, 2001 06:37 PM
