Aftermarket flywheel: is it worth it?
Old Jun 8, 2005 | 03:15 PM
THT's Avatar
THT
Throbbing member
I'm putting a 5th gen tranny and 5th gen clutch and am debating whether or not I should put a Fidanza flywheel in as well. Does anyone have dyno charts or quarter mile passes that prove the flywheel is a worthwhile addition?
Old Jun 8, 2005 | 04:05 PM
RA030726's Avatar
I'm nutty for Nissans
yes it will free up power, but with some drivebiliy differences. On launch you need to give more throttle to avoid bogging. on shifts the revs drop quicker, that can be good or bad, just depends on how you drive. All drivers are different, all cars are different. IMO its not really worth the $500 for one.
Old Jun 13, 2005 | 05:34 PM
THT's Avatar
THT
Throbbing member
Thanks for the input. I will pass on the lightweight flywheel unless anyone has something to say in it's favor??
Old Jun 13, 2005 | 06:16 PM
Super96Max's Avatar
I have one and im happy with it. Definatly a lot different
Old Jun 13, 2005 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
Different but worth the $500 ... Do you have any results?
Old Jun 13, 2005 | 06:20 PM
VQ of Bodom's Avatar
IMO it's worth it. Its not even $500. I got mine for $320 new/shipped.
He has good points, but I drove w/ the stock flywheel for about 4 months until I got my Fidanza. I noticed it revs a lot quicker (UDP also) - and higher gears pull so much harder on the highway
The dyno didnt show any NUMBER gains...but the chart goes up FASTER w/ the fidanza of course.
Think of it like running 100 yds w/ a backpack full of bricks, and then running w/ out bricks. Without the bricks youll be faster, but not stronger.
UNC dood prefers his stock flywheel over the fidanza because he does a lot of track racing, and has his reasons for it.
Like he said, it differs from driver to driver
Old Jun 13, 2005 | 06:28 PM
NmexMAX's Avatar
dot dot dot ...
If the graph went up faster, wouldn't that mean more power production .. So x dyno lasts 10 seconds and y dyno lasts 12 seconds ... both same cars/gear ratio ... That would mean more power ... I'm not trying to flame or anything, just trying to understand, as I too am doing the 5M swap this summer.
Old Jun 13, 2005 | 06:30 PM
THT's Avatar
THT
Throbbing member
No one has any before and after 1/4 mile times to show gains?
Old Jun 13, 2005 | 07:03 PM
BigLou93SE's Avatar
PM bijangxe, he just put one on.
Old Jun 13, 2005 | 07:08 PM
DR-Max's Avatar
From the illustration given and what I've gathered myself, there is no gain. But your car does get up there quicker. And the illustration that sp lit gave is perfect to describe what a lightened flywheel can do. It's lighter so everything in there spins up quicker, the RPM goes up faster, and acceleration goes up. I can see how this would deceive people because quicker accelaraton (0-60mph) should mean that you have more power. But really what changed in the engine that affected the combustion which drives the pistons up and down faster? Nothing. You didn't even touch the engine. You just alleviated some of the load the engine works under by lightening up a component in the transmission making those gears and such spin up quicker.
Another illustration would be why people gut the interior of their cars to lighten it up. The lighter the car, the faster the 1/4 mile run will be. Nothing changed in the engine as a result of that, so no gains but faster times.
Old Jun 13, 2005 | 07:15 PM
NmexMAX's Avatar
dot dot dot ...
bijan's on vacation ...
Old Jun 14, 2005 | 03:58 AM
TomV's Avatar
I have no experience with a LW flywheel on a maxima, but i did put one on a neon once, so i'll add a little...
On that car, it made a significant gain in 1st gear acceleration, and a small gain in 2nd gear too. But, drag racing didnt really show any gains (keep in mind this was a mid-15 sec neon), maybe a tenth. why? Coming off the line was a little tighter window between bog and spin (street tires). On a more powerful front-driver, a lw flywheel would probably help drag times if there's a lot of traction. if its already traction limited in 1st (street tires 14sec maxima) then i am skeptical that the drag times would improve much...though i'd still be tempted to get one knowing how much it helped my old car (on the street, SOTP).... hmm my 130k clutch has to need replacing at some point.
Old Jun 14, 2005 | 05:55 AM
sdoherty_tjm's Avatar
tomv what are you talking about, thats pretty confusing...
how much is a fidenza flywheel?
cus you guys didnt really say if its worth the money
Old Jun 14, 2005 | 09:52 AM
TomV's Avatar
I guess i was trying to make 3 points...
- the light flywheel felt awesome in 1st and 2nd gear on the street, car felt faster but also peeled out easier
- drag times didnt improve too much because launching was harder to do right... car would either bog or spin depending on launch rpm. i think i went from 15.5 to 15.4. Not really a cost-effective mod from the ET/$ perspective.
- if you're close to the traction limit in 1st gear already on street tires (not sure if this is true for your typical modded 4th gen or not) - then a LW flywheel wouldnt help ET much... since the gain is mostly in 1st gear. UNLESS you get more traction with slicks or DRs. then you could use all the extra acceleration that it would offer.
why does it mostly work in 1st and 2nd gear? that's because the motor winds up very quickly in those gears - which means more energy is wasted spinning up the drivetrain. LW flywheels give you back some of this wasted energy.
Old Jun 14, 2005 | 09:53 AM
NmexMAX's Avatar
dot dot dot ...
Neon = Apples
Maxima = Oranges
Old Jun 14, 2005 | 10:45 AM
|Bijan|'s Avatar
UCF Lexus
Fidanza =
Old Jun 14, 2005 | 10:47 AM
bijan do you have one? (if you do)
is it worth the money, and how much did you pay for it?
Old Jun 14, 2005 | 11:27 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by bijangxe
Fidanza =
Oh you're back . . . . Is it worth the .3-.5k?
Old Jun 14, 2005 | 11:37 AM
it costs 300-500 $'s?
Old Jun 14, 2005 | 11:39 AM
Jeff92se's Avatar
I'm needing a caw
It's worth it to me. If anyone likes the UDP, they will love the lighter flywheel. Plain and simple.
Old Jun 14, 2005 | 11:41 AM
whats UDP stand for?
Old Jun 14, 2005 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
Under Drive Pulley, you need to read the thread, and go through the motions .. i.e read the stickys in all gens ...
Read post #6, there he gives you a price of $320 and if you've done a little research, you have seen them for ~500 ..
Post # 9 answeres your post #17 ... Try reading the thread before posting ..,.
Old Jun 14, 2005 | 12:09 PM
renatonetmail
Iam, for obviou$ rea$on$, still on hold to get an Unorthodox Racing Lightened Flywheel as well as their UDP. that combo goes over $500 easily but i drove another 95spd w/ my same mods and damn that things pick up faster than mine. Oh well... i liked it. its getting put. Period.
Old Jun 14, 2005 | 12:35 PM
|Bijan|'s Avatar
UCF Lexus
My advice is to stay as far away as possible from the Unorhadox flywheel.
Old Jun 14, 2005 | 12:43 PM
goodbye15's
I took a different route with getting a lighter flywheel. I took it down to where they resurface flywheels and he took about two pounds off. Only cost me 25 dollars.
Old Jun 14, 2005 | 12:47 PM
Jeff92se's Avatar
I'm needing a caw
I've done this also to one of my stock VE flywheels. They took 3lbs off. Unfortunately, that's not really enough to do anthing. Stock flywheel is about 20-22lbs. The Fidanza for reference is about 10-11lbs. So about 1/2. And that's about what's needed to make a significant difference in performance.
Don't know what bijan has against the Unorthordox unit. Should SPECIFCALLY state what are wrong with them. As with the ring gear etc...they end up weighing about the same or more as the Fidanza. As proved by Blackbird.
bigdogsteve
Jan 31, 2018 04:18 PM
Forge277
Jun 13, 2016 09:26 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
