help identifying leaks...
Old May 30, 2005 | 08:58 PM
DavidT's Avatar
This one is at the tranny (the oil pan is on the right). The leak is not dripping, but it is accumumlating dirt and grease (in the pic. it is in the "shadow" looking area.) Is it common?:
This one is at the angle CPS sensor. Could it be the front main as well?:
Old May 30, 2005 | 09:01 PM
i30ds's Avatar
Armed and Dangerous
Rear main seep... most of us have had it. vqpower.com has a good write up on it.
Old May 31, 2005 | 12:06 AM
DR-Max's Avatar
Check both your valve covers (bottomside), do they show the same signs? If yes, you got leaks coming from there which is trickling down towards below. That's another normal thing that happens to a max especially those close to 10 years old.
I'm replacing the rear main seal on mine tomorrow, the leak on mine is soaking the clutch with motor oil. I'd say the clutch is toast too so I'm putting in new clutch, cover, bearing, and bushing.
Old May 31, 2005 | 04:41 AM
Max96GLE's Avatar
I have some leaking around that area too. I'm not sure if the same problem. I haven't had a change to fix it yet. Here's a picture if
D Mason
Jun 21, 2016 04:43 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
followthadollar
Sep 13, 2015 09:55 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Colossus
Sep 9, 2015 05:46 AM
