Trimming Bumpstops...
Old Jun 3, 2005 | 01:25 PM
statedog's Avatar
Hey guys,
96 gxe with H&R and GR2 shocks...how much of the bumpstop should I trim off? Can I do this with the springs/shocks still in place or do I need to take them off the car?
TIA
Old Jun 3, 2005 | 02:52 PM
njmaxseltd's Avatar
Cut 2 rings off the stock bump stop or use the KYB boots which have a shorter bump stop.
You must have the struts/shocks out and apart to get to the bump stops.
Old Jun 3, 2005 | 06:37 PM
statedog's Avatar
thanks, any advantage going to KYB stops, since i have to take the struts out anyway??
Old Jun 3, 2005 | 06:52 PM
njmaxseltd's Avatar
You can't trim the new style Nissan front replacement units. If your old ones are in good shape, pull the bumper out of the front boot and trim it.
You have to cut the rear dust cover stem on the Nissan unit to shorten it's bump stop. Sort of distroys the assembly in a way.
The advantage of going with the KYB units is that they are a direct replacement unit that work very well on lowered setups.
Old Jun 3, 2005 | 08:32 PM
statedog's Avatar
thanks again.
Old Jun 3, 2005 | 11:12 PM
TrackSmart's Avatar
Yeah, I'd splurge for the KYB bumpstops. They are boots and bumpstops in one and allow for more travel than stock. No cutting required.
On a 1996, I'd imagine your old bumpstops are in pretty sad shape by now. Good luck.
Old Jun 4, 2005 | 03:56 AM
paultyler_82's Avatar
does anyone know if any of Energy Suspension's Universal bumpstops will work with our suspension?
Old Jun 4, 2005 | 09:38 AM
TrackSmart's Avatar
Why not just get the KYB bumpstops? They are cheap, they work well, and you know that they will fit the stock maxima strut as well as the aftermarket struts for our car...
Unless you have them already, why bother with the Energy Suspension brand?
Old Jun 4, 2005 | 09:57 AM
maxspeed96's Avatar
where can I get these bumpstops? and for how much? I just got my tokico suspension kit (Illuminas & Tokico springs) in and I dont know what else I need for this install since I never did it before.
Old Jun 4, 2005 | 10:10 AM
TrackSmart's Avatar
I bought mine over a year ago at: www.cattman.com
Brian Catts is known to be a reputable seller of all things maxima, but you might find them a few dollars cheaper somewhere else. Tirerack.com might also carry them. That's the best I can tell you.
Old Jun 4, 2005 | 10:22 AM
maxspeed96's Avatar
Thanx TrackSmart. Is that all I need in addition to my struts and springs for the install?
Oh yeah, sorry for highjacking your thread statedog.
Old Jun 4, 2005 | 10:29 AM
TrackSmart's Avatar
If i were you I would DEFINITELY change the upper strut mounts and the bearings when you do the install.
I skipped this and less than a year later I changed out the bearings. then a month later I had to do the upper strut mounts. It's tempting to skip this and save $60 (tirerack is selling KYB mounts for $30 each and mine came with bearins, too) but it will be more work for you in the near future.
Not necessary right now, but worth considering...
Old Jun 4, 2005 | 10:33 AM
TrackSmart's Avatar
Are you doing the install yourself? If so, you probably know this, but most autoparts stores will lend you spring compressors, breaker bars, and torque wrenches for free (just leave deposit).
you may need the breaker bar for the strut-to-steering knuck bolts Those bad boys are factory torqued at around 140 lb-ft and were really tough to remove on my car. Also beware of the ABS cable (disconnect it from the strut along with brake cable). Don't let the steering knuck fall when you remove the strut bolts, could damage ABS cable and brake line.
Good luck.
Old Jun 4, 2005 | 10:39 AM
maxspeed96's Avatar
unfortunately, yes. Im on my own it seems..lucky me.
thanx for you help TrackSmart
Old Jun 4, 2005 | 02:11 PM
Ok so if you want to redo your suspension front and back, you need the struts and springs, the KYB Boots/Bumpstops, and what else, just 2 upper strut mounts/bearings?
Old Jun 4, 2005 | 04:01 PM
TrackSmart's Avatar
You might want to change the rear mounts, too. They are really cheap. Only $5 each. I just did this, so yeah, complete list:
Parts:
Struts
Springs
KYB Boots/Bumpstops
Upper Strut Mounts (front and rear)
Strut bearings (only the front has bearings)
Tools:
-Jack and Jack Stands
-Ratchet Set (1/2" is preferable for more torque)
-Spring compressors
-Pliers (to pull out the metal clips holding the brake line to the strut. Or use a hammer and screwdriver to pop it off.)
-Adjustable wrench (for people with ABS, to take off little screw attaching ABS line to the strut. Hard to get in there with the rachet.)
-Breaker Bar or air-tools (optional, but the strut-to-steering-arm bolts are tough to get off without a long ratchet or a breaker bar for leverage. Borrow from autozone.)
-Workbench and vise (optional, but it may be hard to remove the middle bolt on the strut by hand. The entire shaft "spins" if you just try to turn it with a ratchet. You have to hold the strut to get the bolt to unscrew)
-a second jack or a cinder block - anything to rest the steering knuckle on while you have the strut disconnected. you want to keep it near level so you don't damage your brake line or ABS cable by stretching them under it's weight. It's not that heavy, but heavy enough to stretch your brake line or hurt the ABS cable.
-Torque wrench (optional, but ideally you'll torque everything to factory specs when you are done. Borrow one from autozone or a place like that).
-Work gloves (optional, but it's nice not to cut open your hands when you inevitably slip on the wrench or ratchet...)
Last thing: WHATEVER YOU DO, DON'T EVER TAKE OFF THE MIDDLE STRUT BOLT WITHOUT SPRING COMPRESSORS SECURELY ATTACHED!!! MAKE SURE TO POINT AWAY FROM YOU. MAKE SURE THERE IS NO PRESSURE ON THE TOP MOUNT WHEN YOU TAKE OFF THAT BOLT!
Be safe, and good luck. I've gotta get back to work here... I'm wasting way too much time procrastinating...
REDinLV
Aug 15, 2024 12:30 AM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
