swapping 95 headlights for 95's
Old Jun 4, 2005 | 07:46 AM
chillin014's Avatar
I read in the stickies that someone had to replace the CORNER LIGHT HARNESS. IS the harness the part thats attached the the bulb and on the actual corner light? Or the "PLUG" that plugs into that socket part thats on the corner light.
I want to know what i'm supposed to swap out as far as that part goes because i'm going down to pick some up today (most likely) and i want to knock it all out in one trip. thank you.
and any other concerns i will need to know with using 97 headlights and corner lights with a 95 bumper and grill will be helpful to, thanks.
Old Jun 4, 2005 | 07:52 AM
|Bijan|'s Avatar
UCF Lexus
yes the 97-99 corner light harness is different. the bulb is the same...JUST the plug harness. You can use the ones you have now if youre good at soldering or taping them up. Its up to you.
Old Jun 4, 2005 | 07:56 AM
chillin014's Avatar
if its easy, i can do it. i kinda need a little instruction though. this is the plug part so i would need to cut the wires, what like 2? and just resolder the new plug with matching wires?
Old Jun 4, 2005 | 08:43 AM
chillin014's Avatar
okay screw it i'm not gonna swap them.
Old Jun 4, 2005 | 09:09 AM
|Bijan|'s Avatar
UCF Lexus
If you want to go thru life doing everything half azz be my guest.
Old Jun 4, 2005 | 09:11 AM
chillin014's Avatar
excuse me? who said i was doing it half a$S??? not doing it at all is not doing it half ***. i just wanted an easy swap but i see taht theres little things you have to trim off and stuff and i might as well just do a full 97 swap instead of altering little pieces that wont fit together when its all completed.
Old Jun 4, 2005 | 09:17 AM
|Bijan|'s Avatar
UCF Lexus
A full swap? You mean grille, bumper, light housings? As opposed to light housings only?
I just think it'll look stupid if you have 97 headlights w/ 95 corners.... Thats half azz in my opinion
Old Jun 4, 2005 | 09:18 AM
chillin014's Avatar
then i guess you misunderstood because i meant that i'm not going to swap ANYTHING OUT.
in fact the headlights are in my oven now, i'm just going to customize what i've got. same corners same headlights, same grille.
and yes i meant full swap. ALL or NOTHING
Old Jun 4, 2005 | 09:19 AM
|Bijan|'s Avatar
UCF Lexus
Whatever man, its your car do what you want....
Old Jun 4, 2005 | 09:20 AM
mansurxk's Avatar
looks fine, i dont see any difference when i look at my car and a 97, nor does anyone else when i ask about the headlights. (previous owner swapped headlights left the corners)
Old Jun 4, 2005 | 09:23 AM
chillin014's Avatar
how the hell do you pry the lense from the housing
Old Jun 4, 2005 | 09:27 AM
chillin014's Avatar
im swapping them to do the AE MOD so it will look better.
and bigjangxe, what is up with you? i'm not understanding where the drama came from.
Old Jun 4, 2005 | 09:47 AM
|Bijan|'s Avatar
UCF Lexus
Drama?
There's no drama. Your initial question was confusing a little bit. But like I said...whatever, its your car do what you want
Old Jun 4, 2005 | 09:48 AM
|Bijan|'s Avatar
UCF Lexus
use a cro-bar
Old Jun 4, 2005 | 09:50 AM
chillin014's Avatar
yeah i got it. i understand it was confusing, just didnt think i'd frusterate anyone.
alright well, i guess ive got it under control i hope it shows up okay on a 95. (THE AE MOD)
Old Jun 4, 2005 | 10:04 AM
|Bijan|'s Avatar
UCF Lexus
It wil be noticeable....but not AS noticeable with 97-99 lights. Good luck
Old Jun 4, 2005 | 10:05 AM
mansurxk's Avatar
the AE mod on a 95 is very unnoticable. definately get the 97's regardless of the corners, the corners arent very noticable. they make a slight difference, but the 97+ cleans up the car
Old Jun 4, 2005 | 10:07 AM
chillin014's Avatar
uh...its not really that easy to just get some 97 headlights, plus like i said already, i dont want to swap the headlights and have to modify anything to make a custom fit. I would have to get the whole 97 front conversion.
so getting 97 headlights isnt an option right now.
Old Jun 4, 2005 | 10:11 AM
|Bijan|'s Avatar
UCF Lexus
Pics of proof
Old Jun 4, 2005 | 10:14 AM
mansurxk's Avatar
....i didnt know you had to change everything else to make the headlights fit
Old Jun 4, 2005 | 10:19 AM
chillin014's Avatar
Guys, its not an option, I have already discovered the difference. And you don't have to change everything else, I just don't have the money or feel like modifying anything even the slightest bit. Unless someone on the org wants to sell them to me for cheap, andthe modifications won't effect a future 97 conversion.
Old Jun 4, 2005 | 11:15 AM
chillin014's Avatar
Ugh, yall have got me torn now. I can't decide if I should modify my current lights and if I do if ill be able to sell them if I decide to get 97-99's.
Old Jun 4, 2005 | 05:01 PM
Black Maxima
Upgrade to 9007 with your current 1995 lights (do the AE), screw the 97+ lights and you will love the ones you have...
Old Jun 4, 2005 | 05:07 PM
chillin014's Avatar
Haha man, you've got no idea how split down the middle I am about this. We'll see if I can get a deal on headlights, if not, ill go through with it.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
doctorpullit
Oct 28, 2019 10:58 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
