need help... idle screwed up
Old Jun 4, 2005 | 06:27 PM
hacim105's Avatar
i just changed my engine coolant temperature sensor, and i went to reset my CEL, but becuz my ecu screw is broken (it wont stop turning either way) i now can not set it to a high enough idle. the highest i can get my car to idle at is 200. so i cant drive my car. PLEASE HELP!!!
Old Jun 4, 2005 | 06:32 PM
Prophecy1's Avatar
You need to have ur ECU screw re-threaded. ECUdirect.com will rethread that.
Or you can have a used ecu installed. Installation is not eazy but doable.
Proph
Old Jun 4, 2005 | 06:35 PM
hacim105's Avatar
so theres nothing i can do in the mean time? I cant even drive my car.
Old Jun 4, 2005 | 06:47 PM
hacim105's Avatar
is there anyway that i can have autozone reset my idle back to normal? Also my engine revs really wierd between 3000-4000, is this a result of my screwed up idle?
Old Jun 4, 2005 | 07:03 PM
quaker's Avatar
Just wondering, how does the ecu screw affect the idle speed.
Old Jun 4, 2005 | 07:23 PM
hacim105's Avatar
bucuz thats wat sets it...
Old Jun 4, 2005 | 08:04 PM
quaker's Avatar
does not the ecu = the electronic control unit i.e. the computer? What screw on the ecu deals with the idle speed?
Old Jun 5, 2005 | 09:08 AM
Maxed_Out_Maxma's Avatar
hey this is actually my car that this happened to, but is there anyway to reset the car back to the normal idle? Im kinda stuck, and if not who should i call?
Old Jun 5, 2005 | 09:36 AM
hacim105's Avatar
It's the screw that you use to check what codes your ECU is throwing. The same screw adjusts your idle.
Old Jun 5, 2005 | 02:06 PM
madnut's Avatar
If you want a temp solution while your screw gets rethreded, just adjust the gas throddle to a higher setting, that way its like your always pushing the gas a little, but this is only temp dont just leave it like that
Old Jun 5, 2005 | 06:05 PM
how do i do that? ^
Old Jun 5, 2005 | 06:30 PM
madnut's Avatar
Here is the img, instead of adjusting properly like they tell you to do adjust so it doesnt return to idle possition but a lil more open then usual.
Make sure to mark where it was before you start so that you can return it to the original possition.
Again its up to you if you want to do this i am not reponsible for any Damage.
[IMG]ftp://madden.homeip.net/adj.jpg[/IMG]
But like i said this is a temp fix, your car will run high rmps when you drive and will accelarate more then u expect with the gas pedal not pressed, if you have an auto it will start going as soon as you drop into drive so watch out.
Old Jun 5, 2005 | 07:03 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
so your saying the screw also adjusts your idle? which idiot told you this. do you know what an iac is? i always thought that that controled your idle. and the ecu controls the iacv. hmm. if your idle is that low, you have a serious problem. and its not ecu related. check your LTFT and see what percentage it is showing. you probably have a vaccum leak and the ecu cant adjust for it. or a mechanical failure.
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
