9004 to 9007 conversion question
Old 06-05-2005, 10:32 PM
MystA RavE's Avatar
I'm about to do the conversion and I wanted to know if I can just cut the 9004 harness off and swap it for this one... http://cgi.ebay.com/ebaymotors/ws/eB...category=42613
Has anybody done this?
MystA RavE is offline
Old 06-05-2005, 10:55 PM
The Russian's Avatar
what about teh wires and the diffferent wattage of the bulbs....
The Russian is offline
Old 06-05-2005, 11:39 PM
Talyan03's Avatar
there are tab's on the side and you can just sand them. i tied to install the 9004 bulb on the 9007 socket and it worked. remove the tabs. hope that helps
Talyan03 is offline
Old 06-06-2005, 12:31 AM
maximazation's Avatar
i just cut the low and ground wires and swapped them, but i purchased cefiros so im going to have the rewire again, but this time for H4s.
maximazation is offline
Old 06-06-2005, 04:12 AM
browne's Avatar
ive been wanted to try this too... anyone burn there wires by just switching the low and ground wires only?
browne is offline
Old 06-06-2005, 02:56 PM
97MaximaSE's Avatar
now what exactly is the advantage of converting if i may ask
97MaximaSE is offline
Old 06-06-2005, 03:04 PM
bhmax16's Avatar
You'll only burn something if you use higher wattage bulbs unless you upgrade your harness. I run 9007 Nokyas with Nokya 9004 harnesses, just swapped the lowbeam and ground wire
bhmax16 is offline
Old 06-06-2005, 03:10 PM
V^___^V
happyricefob's Avatar
get the 9004 > 9007 harness converter from southwest autoworks. the headlight will be brighter.
or u can save up that $40 and get real HID systems. never worry about ghebay headlights blowing out. i think i spent about $100 on gaybay headlights which i could have just got HIDs. so i recommend HID in the long-run.
happyricefob is offline
Unclejunebug
04-02-2016 05:42 AM
Calabar
10-05-2015 09:57 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: 9004 to 9007 conversion question
