95 to 97 rear conversion
Old Jun 6, 2005 | 11:09 AM
acmax95's Avatar
I have a 95 GLE and a friend of mine recently backed into me. I need a new bumper cover and both driver side taillights.
I was thinking of doing the 97 conversion while i got the car in the shop. Is all i need a 97-99 trunk lid and tails? Also will the 97-99 bumper fit?
I read the how tos but all i saw was a long argument on the topic with no answer.
All help is appreciated.
Old Jun 6, 2005 | 12:07 PM
ArcticW's Avatar
The basics are this......Buy a 97 trunk and tailight set. They'll fit on the car without difficulty. The list of parts you need are as follows..
97' trunklid
'97 brakelights
'97 bumper
All parts will fit . If they don't, don't hesitate to message me.
Old Jun 6, 2005 | 12:16 PM
Magikone69's Avatar
all you need is the trunk lid and tails, bumper isnt required, get the bottom latch too just in case your stock latch doesnt hold it shut
Old Jun 6, 2005 | 12:56 PM
jamesn67
Free bump cause I need 15 posts to start a new thread!
Old Jun 6, 2005 | 01:16 PM
MDeezy's Avatar
or wont open without the key
Old Jun 7, 2005 | 01:57 PM
ArcticW's Avatar
Don't you need a separate key to open the trunk anyways?Just use the keyless entry remote.
Old Jun 7, 2005 | 08:09 PM
MDeezy's Avatar
I swapped keyholes so I can use my same key. Keyless doesnt work I need the 97 bottom latch, it just makes the sound as if you have that lock latch up.
Old Jun 7, 2005 | 11:51 PM
Magikone69's Avatar
yes i was in that boat, it would pop, but nothing happened. my stock latch didnt even keep the lid locked shut at all times. i would slam the lid 5-6 times for it to finally grasp and hold it shut. you may not need it but get the latch off of whatever car u find it just in case, you may never run into another 97+ again and it may be your only opprotunity.
Old Jun 8, 2005 | 11:25 AM
MaxKlinger's Avatar
Just fix what you have, the 95/96 rear end looks better anyway IMO, the 95/96 taillights look better without the red corner wedges by the turn signals as found on the 97-99 models. And I like the spread out "M A X I M A" instead of the letters being scrunched together...but that's just my opinion - to each his own. Whatever you decide, good luck!
Old Jun 8, 2005 | 11:46 AM
ArcticW's Avatar
Word Diggity! At least you can swap back the old setup if the converison is too much trouble...can't say that about every mod.
Old Apr 25, 2009 | 02:32 PM
Ignorantkid's Avatar
Hey can someone help me out i cant post as yet im a newbie but i have a problem i have a 95 max and one day i was cleaning the trunk and this wire came droppin out from inside of the trunk it looked like a switch or something it was rapped around with electrical tape i as like wtf?? i pushed it back in the trunk and closed it next day i tried to open the trunk and it doesnt open I converted the rear to 99 and all it does it make that clicking noise but the trunk still doesnt open. Can it be that wire the dropped down???
Another thing is that i converted the rear to a 99 and for some reason the trunk doesnt line up as good. the right side is ok but the left side has this gap. What can i do to make it line up properly???? Click the link below to see some pictures i took not the best quality but it do. Thanks to all who helps.
Old Apr 25, 2009 | 03:07 PM
driftmax's Avatar
does the trunk sit flush?
Old Apr 25, 2009 | 03:15 PM
Not really. The right side sits in good. but the left side has like this hump to it idk what in the world is making it like that but i think I need to readjusted the trunk. but i still cant figure out why the trunk doesnt open
Old Apr 25, 2009 | 05:01 PM
CARLITO's Avatar
Hey ignorantkid, Do you still have the 95 rear bumper with the trunk? If you do can you send me some more pics if you have them. Thanks
Old Apr 25, 2009 | 06:37 PM
Flava_24/7's Avatar
Boosted Panda
you CAN adjust the latching mechanism to have the trunk sit lower when latched.
Old Apr 25, 2009 | 07:28 PM
When the trunk close should there be a gap between the back window and trunk? or should it be close to the window. Reason why I ask is because the right corner of the trunk is closer to the back window while the left side has a gap between the window and trunk. It looks easy but its tricky
Old Apr 25, 2009 | 11:36 PM
pmohr's Avatar
No more Maximas...
So have you not tried to use the play in the mounting bolts to shift it around a little?
And have you tried using your key in the trunk lid to open it up?
Old Apr 26, 2009 | 03:07 AM
tosheto's Avatar
I played with the mounting bolts and fixed mine some time ago
Old Apr 26, 2009 | 06:05 PM
Thanks man I fixed the latch mechanism it was pushed down to much. So all I did was pushed it back up into place and it worked like a charm . By any chance does anyone here know what the hell is this thing? It came from inside of my old trunk and it connects to the wire hardness I dont know what to do with this wire or was its suppose to do. Image is below.
Old Apr 26, 2009 | 06:19 PM
Flava_24/7's Avatar
Boosted Panda
Thats for your trunk release.
Old Apr 26, 2009 | 07:33 PM
96blackmaxSE's Avatar
boost me.....
wtf you have 95-96 outer tails and 97-99 inners, lolz
Old Apr 26, 2009 | 07:59 PM
tyler5619's Avatar
i vote this guy uses the noobie thread
Old Apr 26, 2009 | 08:30 PM
LOLL i know i have the 97-99 outer tail lights but just dont have enough time to put them on. I have other issues with the car to take car of first.
Old Apr 26, 2009 | 08:33 PM
denice25's Avatar
you need a taillights, trunk and bumper....
Old Apr 26, 2009 | 09:52 PM
f550maranello2's Avatar
uhh.. no he doesn't.. he needs just he outer taillights...
Old Apr 28, 2009 | 01:27 PM
96t/acj's Avatar
Great to see this thread i need to adjust my latch!
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
bbsitum
Sep 11, 2015 04:55 PM
Hdnseek
Sep 9, 2015 05:55 AM
