5spd Tranny Oil plug, Cant open...
I was trying to open the side plug the one you use for checking the level and refilling, the damn thing wount open, i broke my wrachet on it
Is it a left handed screw or somthing ? or is mine just stuck in there?
For the cost of going to a Jiffy Lube (or whatever they're called in your state), its hardly worth doing it yourself. Just make sure you use GL4 75W90 or 80W90. Do not use GL5. I had mine done recently and its cheaper than a regular dino oil change and they dispose of the old gear oil.
The Haynes manual does not provide any explicit instructions for removing the filler plug from the side of the manual transaxle. It just says to remove it and to measure with your finger to feel that the oil level is at the plug opening.
I suspect to loosen it you turn it counter-clockwise.
Hehe i have that manual, simply open the pulg .. basterds!!!
i was using my wrench with a 1.5 foot pipe on it for torqe and it didnt open, the wrench broke thou its suppsed to be 28ftlb tight, I mustev applied more then 100 and nothing
Mine opened w/o much effort. I only used a 1/2" ratchet, no breaker bar needed. Make sure you are turning it counter-clockwise. And be careful because you can end up cracking the transmission case. Try using penetrating oil on it too.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
JoshG
51
09-21-2015 10:41 PM
ag90fox
09-09-2015 12:22 PM
pktaske
09-04-2015 08:40 AM
sdotcarter
09-02-2015 09:53 PM
