0302 how do you fix it plz help
Old Jun 6, 2005 | 02:09 PM
S103100F's Avatar
today i just pulled out 0302 code just wondering how do fix it and what did you do about ?
Old Jun 6, 2005 | 02:13 PM
njmodi's Avatar
Do I get a tax break?
http://forums.maxima.org/showthread.php?t=90535
http://forums.maxima.org/showthread.php?t=403116
To summarize: I would recommend cleaning out the EGR port on the back of the upper intake manifold (also called the plenum). This is not an easy job and it maybe worthwhile to have the dealer do the work. Local dealers quoted me around 200 dollars to pull and clean out the EGR passageways.
Cheers.
Old Jun 6, 2005 | 02:54 PM
97MaximaSE's Avatar
just dont fix it like i did...i replaced almost everything pertaining to this code and still havent solved it so if you do let me know
Old Jun 6, 2005 | 03:01 PM
njmodi's Avatar
Did you pull the plenum and clean the port and EGR tube?
Old Jun 6, 2005 | 07:38 PM
97MaximaSE's Avatar
of course along with removing the throttle body and using a coat hanger to clean out the passage
Old Jun 6, 2005 | 07:41 PM
njmodi's Avatar
and you still have the code?
Old Jun 6, 2005 | 07:57 PM
97MaximaSE's Avatar
yup changed the soleniod, checked function of the egr valve and cleaned out the passages...still have that fun 0302 code......luckly it doesnt really affect driveability so it doesnt bother me so much anymore....i always throw the 0707 code cause of my gforce ecu anyway
Old Jun 6, 2005 | 08:17 PM
MystA RavE's Avatar
does this code affect gas mileage? I also have this SOB problem. My local shop told me that the way to fix it is to start replacing from the cheapest part...but that doesnt sound like a bright idea to me.
Old Jun 7, 2005 | 03:47 AM
97MaximaSE's Avatar
i dont think it does...it just seems to help emissions
Old Jun 7, 2005 | 02:51 PM
DcMaN's Avatar
i also have this problem except my car runs like **** my idle is very vicious it shakes my car real bad i have almost no power on accerlation and i have a huge amount of hesitation.
Old Jun 7, 2005 | 02:55 PM
97MaximaSE's Avatar
im telling you if you wanna try some coil packs this weekend let me know...i have a bunch lying around and you live about 10 min away
this also depends on wether or not i get my car back since my pcv grommet fell into my engine and the new one takes 2 days to come in.....also i broke another wire in my harness and need to resplice and make it longer
Old Jun 7, 2005 | 08:38 PM
DcMaN's Avatar
i had a friend and i tried his coil packs that work great and that didnt help : ( Im dropping off my car to the guy who put my engine in. Ill let you know what he says. Unless you want to help me take the intake manifold off
Old Jun 7, 2005 | 10:12 PM
MystA RavE's Avatar
Thats not related to 0302...I have that and my car runs perfectly.
Old Jun 7, 2005 | 11:42 PM
DAVE Sz's Avatar
Hooooooonda.....
Well I'll be damned. You're not gonna believe it but there is a link in the HOW TO that shows what to check and how to check it. Your lazy *** should be banned.
http://forums.maxima.org/showpost.ph...86&postcount=5
Old Jun 8, 2005 | 03:59 AM
97MaximaSE's Avatar
i think the only reason i havent been able to remove the code yet is because i have a short or a wire break in the harness pertaining to the soleniod. when hooked up to the consult it shows the soleniods never stays open for more than a split second like its being shorted out
Old Jun 8, 2005 | 09:33 AM
Chickan's Avatar
Vacuum leak?
Old Jun 8, 2005 | 11:46 AM
MystA RavE's Avatar
If anybody local can check it out for me i'd be willing to pay....
Old Jun 8, 2005 | 12:17 PM
DcMaN's Avatar
i brought mine to the guy who put my engine in today does your car idle terrible ? If so the egr valve seems to stuck open. He still has my old motor so hes using it from my old motor and putting it on the newer one
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
