Bad MAF?
Old Jun 7, 2005 | 02:02 PM
texasluva's Avatar
Bad MAF?
So every once in awhile my maxima won't start. I changed the fuel filter and it didn't help. It just cranks and won't fire. When I push on the gas it makes a pop noise and starts right up. What are the simptoms of a bad MAF? Does anyone have any ideas. I have a CAI and Full exhaust so I don't know if that has anything to do with it.
LET me KNOW.
THANKS
Old Jun 7, 2005 | 02:25 PM
DonOfDesperados's Avatar
Im having the same problems as you are, even having the popping noise when i try and crank it. So if you ever get an answer please. let me know because i been running around with the car like this for about a month now.
Old Jun 7, 2005 | 05:18 PM
texasluva's Avatar
Anyone!!!!!!! please post. it's a real concern
Old Jun 7, 2005 | 11:38 PM
maximazation's Avatar
symptoms of a bad MAF sensor would be stumbling and hesitation in all RPMs or sometimes the car dont accelerate beyond a certain RPP (usually lower RPM range) and if its completely out, the car would start and idle, but once you get on the gas, the car will die.
Old Jun 8, 2005 | 03:50 AM
njmaxseltd's Avatar
Check both crank position sensors and the cam angle sensor.
Old Jun 8, 2005 | 09:51 AM
texasluva's Avatar
Good idea i'll check those sensors. This may be a dumb question but where are those sensors?
Old Jun 8, 2005 | 10:04 AM
Bobo's Avatar
Buy a Haynes manual immediately, they're cheap and required reading! The crankshaft position sensor is located on the aluminum oil pan below the crankshaft pulley (see diagram 9.2, section 6-12 Haynes) and the camshaft position sensor is located on the timing chain cover (see diagram 10.6, section 6.13 Haynes).
I can find no reference to a cam angle sensor.
There was a thread a few days ago re: the camshaft position sensor with a picture posted. You may want to check that out.
Old Jun 8, 2005 | 10:19 AM
texasluva's Avatar
Thanks I appreciate the posts i'll check out my book when I get home.
Old Jun 8, 2005 | 10:21 AM
Bobo's Avatar
Good idea, too bad it wasn't bedtime reading last night, lol!
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
