dash lights went out
i recently painted my dash a few days ago (came out nice, i love it!!) and i put everything back exactly how it was... all connections were the same as when i took the dash pieces out... well i was driving at night and i noticed some of the buttons dont light up now... hmmmmm??? the defroster and hazard lights dont work and the buttons on the my automatic climate control dont work, but the display does... im def confused y this happened b/c im positive all the connections were right when i reinstalled the dash... any ideas???
My auto climate control lights all blew out from when I replaced my broken clock. My guess is that you maybe didn't disconnect the battery upon removing everything? I didn't do that the first time and I think that is what caused some things to blow. Now I always disconnect the battery and haven't had a problem since then. Just a thought. I painted my dash as well and it also came out awesome. Now I'm redoing all my interior lighting with red LEDs. I've ran into some problems along the way but I have most worked out now. Goodluck, but I have a feeling you didn't disconnect the battery and will need to replace the bulbs (might as well do a LED mod while you have everything opened up) if you know how to solder. If not you can learn very quickly, I learned in 2 min
hmmm ya i didnt disconnect the battery... that would make the lights blow??? if thats true that should def have been the first thing in the write up!! but anyway ya i am gonna do the LED mod, i already bought the LEDs... super white and a red combo
Well, I don't know if there is any proof that not disconnecting the battery will cause the lights to blow but it did happen to me so I'm just speaking from experience. Plus you're supposed to disconnect the battery when changing your headlights so I don't know why the same rule wouldn't apply to any other light in your car as well, although we all know the headlights are the most sensitive of the bunch. When I took out my climate control every bulb was blown though, so I assumed it must have been the battery issue. Take it with a grain of salt though, it's only my guess as to what happened since the same thing happened to me in the past
Originally Posted by JPMax
Make sure the dimmer dial isn't turned all the way down.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
