Write up on how to change TPS SEnsor
See section 6-8 of your Haynes manual. You know the one you read at night to put you asleep.
The TPS is mounted on the side of the throttle body and connected to the throttle shaft. To replace, disconnect the cable from the negative terminal of the battery.
Remove the air intake duct and disconnect the TPS and wide open/closed throttle switch electrical connectors. Remove the two retaining screws and separate the TPS from the TB. Install the new TPS leaving the mounting screws loose. Adjust the TPS as described and tighten the screws securely.
The Haynes manual describes how to adjust the TPS but I'm not going into that. Get a friggin' manual!
vqpower is back up - didn't notice it there. The haynes manual has everything you need - the only pic that anyone can have of it, is where the TPS is and what screws you have to loosen. And the Haynes has a pic of the TPS - so I don't know what other pics you need.
sdotcarter
09-02-2015 09:53 PM
