Lower Intake Manifold - help-
Old Jun 11, 2005 | 08:17 AM
MPMoney$'s Avatar
Does anyone know how hard it is to replace the lower intake manifold?
I can do oil changes, brake work, springs & struts, light body work, replace alternator, stuff like that.
I have to replace me lower intake manifold now - Cali. Spec.
Just wanted to know if anyone has done it before, how hard is this?
Old Jun 11, 2005 | 10:52 AM
JwaxMax99's Avatar
Lower intake, not sure what you mean......
Old Jun 11, 2005 | 10:56 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
what is a Lower intake Manifold?
Old Jun 11, 2005 | 10:57 AM
JwaxMax99's Avatar
Do you possibly mean lower exhaust manifold......?
WielkiWaac's Avatar
MaximaDriver
open Haynes book
Old Jun 11, 2005 | 11:03 AM
CystumMax's Avatar
Originally Posted by WielkiWaac
open Haynes book
Well i don't have it in front of me. Why can't you explain? Teach me something....
Old Jun 11, 2005 | 11:10 AM
JwaxMax99's Avatar
Well, you must mean the intake manifold, it's on top of engine. If you are new to your Maxima and mechanics and repairing cars in general, removing intake would be a challenging first project I think.....?
Old Jun 11, 2005 | 11:13 AM
WielkiWaac's Avatar
MaximaDriver
i dont ahve it either, but i have this
http://www.autozone.com/servlet/UiBr...3d801f4ca2.jsp
READ IT!!
Old Jun 11, 2005 | 11:16 AM
matty's Avatar
There is a lower intake manfold but why do you want to replace it ??
Its really not that hard...all the stuff comes off the upper, the upper comes off, than the lower just unbolts and comes off...make sure you replace all gaskets...most of them are one time use, especially the upper manifold gasket
Alot of guys replace the Upper Intake Manifold and put on a different manifold (MEVI)
-matt
Old Jun 11, 2005 | 11:17 AM
CystumMax's Avatar
Wrong Engine
95-99 Are vq30de
Old Jun 11, 2005 | 11:21 AM
WielkiWaac's Avatar
MaximaDriver
Wrong Engine
95-99 Are vq30de
there is 3 engines, vq30de is on the battom
Old Jun 11, 2005 | 11:32 AM
DAVE Sz's Avatar
Hooooooonda.....
Most of you are idiots. Our intake manifold is made of two parts, the upper and the lower.
Old Jun 11, 2005 | 11:41 AM
WielkiWaac's Avatar
MaximaDriver
thats what im trying to show them on link which i posted
Old Jun 11, 2005 | 12:23 PM
MPMoney$'s Avatar
Thx Dave - I do realize this.
My Max isn't passing emissions right now in the state of Mass.
I get a check engine code of P1130 - which is the swirl control valve / swirl solenoid.
This little piece of **** is only found on Cali. Spec. Maximas - ie MINE.
My local Nissan mechanic said he has seen this type of bull**** before and I'd have to replace the entire lower intake manifold. So----
this isn't something I so much want to do, as I have to do it to get an inspection sticker.
So-- anyone is any suggestions or comments would be great.
I'm alittle skeptical about this whole deal.
-Matt
Old Jun 11, 2005 | 05:28 PM
Zack342's Avatar
-Matt
its not too bad i have done it before when i removed the lower intake manifold from my I30. Cali spec should be exactly the same.
Old Jun 11, 2005 | 08:40 PM
nismology's Avatar
Well if you want to get technical, the intake manifold is actually the lower portion. The upper is called the intake plenum/collector.
Relax man...
Old Jun 11, 2005 | 11:00 PM
eckohb's Avatar
had he got technical, none of the above would have understood what he was talking about. If he meant exhaust manifold, im sure thats what he would have said.
Old Jun 11, 2005 | 11:42 PM
DAVE Sz's Avatar
Hooooooonda.....
This is the 4th gen forum. If I got technical no one would've understood anything.
Old Jun 12, 2005 | 12:25 AM
DR-Max's Avatar
Yep the bottom half is the intake manifold, the upper part is the intake manifold collector. The intake manifold mounts inbetween the cylinder heads. Also, the fuel rail assembly mounts onto the intake manifold. See page 3-21 of the Chilton Nissan Maxima 93-98 repair manual.
Old Jun 12, 2005 | 07:20 AM
THT's Avatar
THT
Throbbing member
1. Detach everything connected to the upper IM
2. Remove the upper IM
3. Remove the fuel rail and injectors
4. Remove the IM
5. Replacement is the opposite.
user 11122324
42
Jul 18, 2022 03:35 PM
Fbana41
Aug 29, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
bumpypickle
Sep 19, 2015 01:07 AM
