Tranny problem !!!!
Tranny problem !!!!
Hi guys here is my dilema ...I had to replace my clutch and also the input shaft bearing and seal ...well after I put evething together in the pouring rain until 11:30pm for some reason the tranny stays on reverse there is no neutral although the sihfter is on the neutral position the car goes on reverse ,if I shift it to 5th it goes on reverse ,if I shift to reverse it goes on reverse , if I shift to 1st it dies , if I shift to second gear the shifter gets stock !!! someone help
Originally Posted by 4thgenx42
Ooooooh, man that sounds serious. Did u you do the clutch yourself? If you didnt take right back to he mechanic who did. It sounds like a clutch problem.
Hi guys thanks for all the feedback I will open it again and check but as far as I know everything was put back the same way I took them out ...If I didn't put the links right how would I know if they are in the right spot ????well I will find a schematic of the tranny and check !!!
Thanks to all
Thanks to all
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
