headers buzzing?
Old Jun 12, 2005 | 07:06 PM
KDog125's Avatar
headers buzzing?
whenever i rev high or downshift and rpms go up headers seems to buzz a lot and kinda vibrate?? what could this be and could it be normal?
Old Jun 12, 2005 | 07:29 PM
THT's Avatar
THT
Throbbing member
How do you know the headers are the culprit? Sounds more like a downpipe flex section issue to me.
Old Jun 12, 2005 | 08:08 PM
sunten1
take a picture of your engine bay and then circle what is making the noise...i think you got some parts mixed up...
Old Jun 12, 2005 | 08:32 PM
Bluemax95's Avatar
Mine does the same thing. I have stone racing headers and y. After I checked things out with an automotive s***hoscope I found I had blown the front header to pipe gasket. (by the way Im still looking for replacement gaskets) Ive had a set custom cut only to blow it again in a few days. (It was some crappy cardboard material I doubted from the start). Im currently replacing my tranny, clutch, and axles so I stoped tryiing to fix the leak for now.
Old Jun 12, 2005 | 08:33 PM
Bluemax95's Avatar
you can't say st eth o scope??
Old Jun 13, 2005 | 12:36 AM
KDog125's Avatar
yea but it started doing that the first day i got the headers installed so i dunno how i coudlve blown the gasket the first time driving it so i dunno wat it could be..maybe its normal...i heard that someone who has same headers is me it buzzed a little bit but i dunno if as extreme...
Old Jun 13, 2005 | 10:56 AM
Bluemax95's Avatar
You could get a leak if the headers didnt mount flush to the heads (ie one warped) or if the header didnt fit square with the y, exhaust could leak around. check to see if you have exhaust build up around the header or on the engine near a junction (black sooty residue). Also check the motor mounts. if the engine torques too far back when you rev high, this could cause your exhaust to flex at the header to pipe area creating a small space for exhaust to leak around the gasket.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
Maxboy23
Sep 4, 2015 06:04 PM
