b-pipe and exhaust system
ok the whole b-pipe topic and exhaust system topic has been brought up many a times.. but i do have one stupid question that i will most likely get flamed for... im lookin into the greddy sp2 exhaust system.. is a "b-pipe" part of the exhaust system or is the b-pipe a totally different thing that connects to the system..
Originally Posted by tekneekzz
that doesnt really help..
http://www.jatan.net/exhaust.jpg
http://maxmods.dyndns.org/index.php?MaximaPerformance
I'm planning on keeping my stock cat, but it's up to you (if you want to spend more money or not) http://maxmods.dyndns.org/index.php?...yticConverters
Since you're in IL, your cat bolts are probably rusted so if you can't get them off, you might have to go to an exhaust shop to have them torched off
actually, i live 50 miles from chicago, but my maxima came from dallas three years ago, i just got it a month ago, but it has abolutely no rust. i heard a few sound clips and it sounds much better with the y-pipe and that high flow cat, so ill just do it for the sound
Originally Posted by sdoherty_tjm
if you get a y-pipe, should you get a high flow cat at the same time? does it matter? i heard it makes teh job way easier if you do both at the same time, but is it worth the extra money?
so the greddy sp2 exhaust sytem has the b-pipe included?
Originally Posted by JaTaN
"MaximaCatbacks: Catback systems, consisting of a B-pipe and Muffler
MaximaBpipes: B-pipes, part between the catalytic converter and muffler
MaximaMufflers: Mufflers, after the B-pipe, also known as rear sections"
Originally Posted by JOMAN
hiflow cat=pollution
The outer layer of the original muffler is rusted and peeling.
I have noticed that the outerlayer of the original muffler (never changed) is rusted and feeling off (dangling). It looks really ugly.
There is no rusted holes and the muffler is working without any unusual noise.
Is it time to replace it?
If not (since it is working), can I peel off the surface to make it look better?
Originally Posted by udienow
Nonsense, high flow cats still filter the exhaust gasses just as well as the stock cats. Just faster. People with these on have said to still pass emmissions even in the most strict states.
jus my thoughts.
I got the Greddy SP2 with a Warspeed Y-pipe it sounds great!!! check my cardomain I don't have sound clips but since your in IL my sure I'll meet you so you can hear it. Mang it sounds mean *** hell only problem is that i lose low end power i you can fell it, but i gain in high-end power
Not true. I have emissions numbers from before and after getting full exhaust (with new high-flow cat). My numbers were almost exactly the same. Some gases were slightly lower, others slighly higher. Really, no significant difference.
NYC metro area has among the strictest emissions requirements in the country, too, and I was well below. Just like before the new exhaust and cat.
HOWEVER, you won't get any HP (not measurable anyway) from getting a high-flow cat.
no gains, and it doesn't last as long as OEM.
