transmission fluid
Old Jun 13, 2005 | 05:10 PM
kasemodz's Avatar
transmission fluid
Can lack of transmission fluid affect jerkiness?
Old Jun 13, 2005 | 05:30 PM
NmexMAX's Avatar
dot dot dot ...
Typically no. Auto or 5speed?
Old Jun 13, 2005 | 05:49 PM
kasemodz's Avatar
its auto, well how about power steering fluid?
Old Jun 13, 2005 | 05:52 PM
NmexMAX's Avatar
dot dot dot ...
Your problem seems pretty strange unless you could explain in more detail.
Old Jun 13, 2005 | 06:03 PM
kasemodz's Avatar
well basically I'm trying to find the cause of this problem. I have another forum "big jerkiness?" which explains the problem in more detail.
Old Jun 13, 2005 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
I read it, and seem to be the only one responding. Problem sounds fuel related but taht would most likely cause it to die/stall. And when you say rev to 3500 RPM, do you mean you neutral drop it so it doesn't die, or ??
Old Jun 13, 2005 | 06:45 PM
kasemodz's Avatar
no I don't shift gears. When I rev it its still in drive gear. Do you think it could be a transmission problem? Sometimes I smell this thing burning and then it goes away. I'm definetly checking my tranmission fluid tommorrow.
Old Jun 13, 2005 | 07:32 PM
NmexMAX's Avatar
dot dot dot ...
I would check it (the fluid) ASAP because if it still revs, but goes nowhere definately the transmission.
Old Jul 1, 2005 | 11:32 AM
1995WhiteMaxima's Avatar
no it would not affect it
Old Jul 1, 2005 | 12:39 PM
dr-rjp's Avatar
Define "jerkiness?"
Are you talking about slipping? Hard shifts? Shaking? Does turning off the O/D make any difference?
Old Jul 1, 2005 | 12:51 PM
FishyMan's Avatar
fluid of anysort MAKES A DIFF. brands, fresh vs old do matter.
my other car shifted hard, and after changing it, the problem, jerkiness on its downshifting went away BIG TIME. so yes it matters. ur shifts will and should be smoother w/ new fluid. but if its not a matter of fluid, then ur tranny has probs..
Old Jul 1, 2005 | 02:53 PM
MaxGordon7's Avatar
where can i get matic d fuild for the max? dealer the best place?
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
