Just failed smog check
Old Jun 15, 2005 | 03:44 PM
masterB's Avatar
The CO and NO is fine, but the HC is a little bit more than allowed. Max allowed is 54 at 15mph test and 37 at 25mph test, I have 58 and 49. My car has a cold air intake and a Y pipe. Does anyone have similar problem and how do you get your car pass the smog check?
Old Jun 15, 2005 | 03:52 PM
NmexMAX's Avatar
dot dot dot ...
Did you let it warm up beforehand? Do you have the main cat still in place?
Old Jun 15, 2005 | 04:14 PM
masterB's Avatar
yea the main cat is still there. how long should the warm up be? should I be driving the car to warm it up or just let it sit to warm up?
Old Jun 15, 2005 | 04:45 PM
THT's Avatar
THT
Throbbing member
Get the car to operating temp then do some spirited driving. Take the car in, don't turn it off and get it tested. You'll pass.
Old Jun 15, 2005 | 04:52 PM
Bobo's Avatar
How far did you drive and at what speed and how long was the engine on before you were tested?
Old Jun 15, 2005 | 08:50 PM
Supermax95's Avatar
the car needs to warm up a bit to open up the precats or something, atleast thats the story with a calispec.
Old Jun 15, 2005 | 09:39 PM
masterB's Avatar
drove about 2 miles and sitting with the engine on for 5 mins. I guess that isn't enough. I will drive at least 5 miles and do some pedal to the metal driving before the test again tomorrow
Old Jun 15, 2005 | 09:48 PM
Dave H.'s Avatar
I say drive on the freeway at least 10-15 minutes or in town 20 minutes. That'll get it nice and warmed up. You don't need to go pedal to the metal. Just get it warmed up. I thought everyone knew to get their car warmed up properly before testing emissions. Hmm...
Let us know how it turns out tomorrow.....thanks...
Old Jun 16, 2005 | 05:58 AM
Bobo's Avatar
Drive further and warm the car up longer. Don't turn it off when you get to emissions testing.
When was the last time you changed your spark plugs, air filter, oil & filter?
Old Jun 16, 2005 | 06:06 AM
sdoherty_tjm's Avatar
if you have a y-pipe then your precats are gone, with out the precats you'll fail if its not warm, you need to let it warm up for the actual cat to work
Old Jun 16, 2005 | 06:37 AM
NmexMAX's Avatar
dot dot dot ...
9 posts that state the same thing ... THT IMO was the best... any other votes ...
Old Jun 16, 2005 | 06:39 AM
Bobo's Avatar
Not to usurp your duties, NmexMax but this thread sucks! (Where is the icon)?
Old Jun 16, 2005 | 06:42 AM
NmexMAX's Avatar
dot dot dot ...
hehe I know I know ... It started out ok ... But it's in the stickys, and I'm trying to be nice today .. Also, he hasn't chimed in so either he took his car in cold or there;s something else wrong ... But at it;s CURRENT state
Old Jun 16, 2005 | 08:28 PM
masterB's Avatar
I'm f***ed!! I went to do the smog check after the car warmed up completly, and I still failed the god damn smog check. I need ideas what I need to fix to pass the smog check. My worst case is borrow a stock y pipe from someone to pass the test but I really don't want to do that. HELP ME PLEASE.
Old Jun 16, 2005 | 09:00 PM
Bobo's Avatar
What were your readings relative to the first failed test? Do you still have your stock air box? What make of y-pipe do you have? What did you do with your OEM y-pipe? They are quite expensive and you should have hung on to it.
Also what year is your car and how many miles are on it?
Old Jun 16, 2005 | 09:05 PM
Supermax95's Avatar
hrm....y pipe b pipe catback and pop charger i passed no problems....maybe cuz mine is a calispec?
Old Jun 17, 2005 | 12:21 AM
madnut's Avatar
How old is your CAT? it is quite possible that your cat is just old and needs to be replaced.
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
Jay556
Sep 12, 2015 05:50 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
sdotcarter
Sep 2, 2015 09:53 PM
