LED ignition trim ring mod...
Old Jun 15, 2005 | 04:16 PM
D-Bo's Avatar
Droppin logs
I've spent an hour searching and google was no help at all. So if this is somewhere obvious that I have overlooked I apologize.
I know that I have seen a write up for changing the color in the ring that lights up around the ignition key switch. Can somebody point me towards it?
Thanx.
Old Jun 15, 2005 | 04:57 PM
nismology95
i heard ManualMaxima is the LED king, i saw on his cardomain his setup, try and PM him.
Old Jun 15, 2005 | 06:58 PM
MAXRB8's Avatar
Here's the correct way:
http://forums.maxima.org/showthread.php?t=390851
I ended up cutting the end and soldering my blue LED to two wires and connecting that way.
Old Jun 16, 2005 | 11:17 AM
meanbean's Avatar
I can't believe I'm saying this but if you want to ghetto rig this mod then just use the magic marker trick. The 74 bulb will not fade out the color for a long time so if your scared to solder then just use a magic marker. Should take all of 5 minutes to perform this mod the ghetto way.
Old Jun 16, 2005 | 11:54 AM
JetBlackMax83's Avatar
^Much respect to the lighting in your car but i find that idea idk blahhh can define my feeling for it, it takes two seconds pop it off swap it out with a #74 wedge led did it to mine nice and bright and no hot spots either im happy with white
Old Jun 16, 2005 | 12:00 PM
meanbean's Avatar
LOL, I would not do it the ghetto way myself. I was throwning it out there as an alternative for the people scared to solder. Thanks for your props.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
mpbclutch33
Dec 26, 2015 11:11 AM
BobTX10
Oct 7, 2015 08:43 AM
