need Help, just installed budget y pipe and UDP, car is sputtering
Old Jun 15, 2005 | 07:53 PM
mbb6's Avatar
Not sure if there is any correlation, but my car acts like it is choking when trying to accelerate, sputters and hesistates. My obd2 scan tool reads, 0401 intake temp sensor. This sensor plugs into the stock airbox, but i have had a short ram intake for over a year and have not had this problem. Also I am getting, 0325 knock sensor, i do not believe that this effects acceleration. Could it be the Y pipe from budget??
Old Jun 15, 2005 | 07:55 PM
njmodi's Avatar
Do I get a tax break?
Sounds like your MAF... check if that is plugged in properly.
Old Jun 15, 2005 | 08:06 PM
mbb6's Avatar
replace that with an used MAF, did fine
was running well until the y pipe went in today, if not he maf then what else migt it be???
Old Jun 15, 2005 | 08:07 PM
njmodi's Avatar
The y-pipe alone will not cause these problems (at least I don't think so). Perhaps the O2 sensors were damaged during the installation.
Old Jun 15, 2005 | 08:19 PM
mbb6's Avatar
makes sense
will get this checked for tomorrow.
Old Jun 16, 2005 | 04:47 AM
njmaxseltd's Avatar
The UDP has a pickup for the crank position sensor (REF). There have been issues with hard starts and engine performance after a UDP install. Go over your work and make sure the timing ring is correctly installed on the UDP. It could be defective.
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
