throwout bearing prob?
Old Jun 17, 2005 | 03:14 PM
nadir_s's Avatar
vicodin ... gift of life
hi guys
Alright, so a quick recap ... last month, I had a problem. After some long driving, I came home and as soon as my wheel hit the driveway to park, I hear this *POP* sound and lose half the pressure in the clutch pedal. Didn't see any fluid anywhere ... when I pushed down on the clutch pedal, I would hear a whirring sound and my clutch engages really low and when it does, i'd feel a shuddering.
I did know that my clutch hose has been slowly leaking for the past 2 years and that i'd just fill the clutch resevoir every couple months and it was fine.
OK, so I had a local ORG member (very experienced) replace the slave cylinder and put in a replacement SS clutch hose. That fixed the whirring sound... however the clutch still engaged low and i'd get some of the shuddering. He recommended that I continue driving the car as-is because we felt the problem probably wouldn't worsten or destroy anything else.
so now, 2-3 weeks later, i push in the clutch pedal as im driving and now the pedal won't come back up. It's strange though, it's not like the pedal is all soft or anything. I'd go in half way normally and then snap to the floor. I looked at the hydraulic and didn't see any leaking. I used my hand to "pump" the pedal, and now I see brake fluid around the slave cylinder area.
I called up my friend and he thinks it could be the throwout bearing finally crapping out and the clutch fork is stuck open .. and now i'm thinking that's why the fluid is being "forced" out of the slave cylinder because the clutch is holding open. When i start the car, the metal whirring sound is alot louder and constantly there.
What do you guys think? i'd think the fluid would come back out the clutch resevoir instead of the slave cylinder.
Old Jun 19, 2005 | 07:49 PM
goodbye15's
you definately have a problem with your t/o bearing. replace it and then bleed the system again.
Old Jun 20, 2005 | 04:49 AM
maxgazm's Avatar
could of broken off one of the springs on the clutch plate. The spring can pop out if you manage to break the plate that hold the spring in. The springs would go either into the pressure plate, or the flywheel.
Old Jun 20, 2005 | 04:57 AM
sdoherty_tjm's Avatar
i have the shudder and the whiring but whiring is when clutch is not engaged, same problem? but my clutch pedal feels normal fyi
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
